Here's some ideas from a guy in Germany: http://www.treefinder.de/ideas.html
Question: Is it impossible to exceed the limits of the efficiency grade as per the heat-to-mechanical-energy Carnot cycle?
As energy can't be created nor destroyed, only converted from one form into another, theoretically then it should be possible to convert heat into mechanical energy with very few losses, mainly friction I'd imagine, which of course produces more heat, which of course also could be recycled in the process to further boost performance.
It would be nice to start off with some device which offers say 50% efficiency to start with, after that then experiment ways to further enhance it, perhaps trying to include some form of pulsing somewhere in order to be able to impose mechanical or heat (or whatever) resonance along the way, etc etc, just brainstorming here.
Or are we forever bound to the about 40%-ish maximum COP as per Carnot?
One idea that springs to mind while writing this is not to rush things in the process, I.E if the process is performing at peak performance from the start only to slowly decrease to zero, which would be when the heat source has the same temperature as the surrounding temperature, then it could be of interest to store the mechanical energy in say batteries from the very start, so the end user payload could vary over time, that way (nearly) all the heat would be used in the process from start to finish.
