by the way...
I'm going to give you all some info to use:
if working on the injector Matrix VIC Bobbin Coil...
You Wont Find This Info Anywhere Else...
Primary:
21AWG .028Ga 200 turns
Copper Wire
3 Layers Thick.
80FT of Wire
1.0216 OHM's per spool
12V@1.5A 20Watts Max
1.2A max on the wire...
secondary:
44AWG .0020Ga 6,500 Turns Per Cavity. 200Layers Thick per cavity.
84,500Turns Per Spool. ( 13 Cavity's)
2,000FT per Cavity, 26,000FT Per Spool.
Copper Wire
67.34Kohms per spool ( 67,340,000 Ohms)
Chokes:
***Bifilar Wound, 16.331932 Ohms Per Ft
36.5AWG, .0047GA, 125Turns per Cavity, 25Layers Thick per Cavity
1625Turns Per Spool ( 13 Cavity's)
55Ft Per Choke Per Cavity, 715Ft Per Choke Per Spool.
430FR Stainless Seal
11.7Kohms per choke.
oh my brain...
not done yet!
now for the fun stuff:
Total resistance of 67430023.4 OHMS + RE
Z Secondary circuit= 67363478.54 Ohms.
add 6.7K ohm resistor in parallel with primary coil
Z Primary circuit 6701.02 Ohms.
if i got all this right you should be matched and ready to inject... wow what a workout.
wow that only took all morning...
me bran hearts
Shew... I'm taking the rest of the day off. ,
