CountApplication #DateTesla Motors, Inc. patents (updated weekly)) :)12014015225806/05/14Steady state detection of an exceptional charge event in a series connected battery
element
22014015225906/05/14Response to detection of an overcharge event in a series connected battery element
32014015226006/05/14Response to detection of an overdischarge event in a series connected battery element
42014015231506/05/14Transient detection of an exceptional charge event in a series connected battery element
52014015315006/05/14Dynamic current protection in energy distribution systems
62014012186605/01/14Fast charge mode for extended trip
72014012186605/01/14Fast charge mode for extended trip
82014009310704/03/14Automated audio optimization system
92014009502304/03/14Vehicle air suspension control system
102014009502904/03/14Sunroof control interface
112014009503104/03/14Sunroof control interface utilizing position presets
122014009599704/03/14Audio system optimization interface
132014009600304/03/14Vehicle audio system interface
142014009605004/03/14Method of launching an application and selecting the application target window
152014009605104/03/14Method of launching an application and selecting the application target window
162014009606904/03/14Method of selecting an application target window in a user interface1
72014009310704/03/14Automated audio optimization system
182014009502304/03/14Vehicle air suspension control system
192014009502904/03/14Sunroof control interface
202014009503104/03/14Sunroof control interface utilizing position presets
212014009599704/03/14Audio system optimization interface
222014009600304/03/14Vehicle audio system interface
232014009605004/03/14Method of launching an application and selecting the application target window
242014009605104/03/14Method of launching an application and selecting the application target window
252014009606904/03/14Method of selecting an application target window in a user interface
262014008880903/27/14Detection of over-current in a battery pack
272014008880903/27/14Detection of over-current in a battery pack
282013033770512/19/13High voltage cable connector
292013032751112/12/13Passive air bleed for improved cooling systems
302013032853112/12/13Charge rate modulation of metal-air cells as a function of ambient oxygen concentration
312013032751112/12/13 Passive air bleed for improved cooling systems
322013032853112/12/13 Charge rate modulation of metal-air cells as a function of ambient oxygen concentration
332013030747511/21/13Charge rate optimization
342013030747611/21/13Method and system for servicing high voltage battery packs352013030747811/21/13Secondary service port for high voltage battery packs
362013030748011/21/13Self-discharge for high voltage battery packs
372013030749111/21/13Bidirectional polyphase multimode converter including boost and buck-boost
modes
382013029325111/07/13Wire break detection in redundant communications
392013029422211/07/13Host communications architecture
402013029452911/07/13Robust communications in electrically noisy environments
412013029453011/07/13Redundant multistate signaling
422013029795411/07/13Host initiated state control of remote client in communications system
432013028455910/31/13Park lock for narrow transmission
442013028560210/31/13Integrated inductive and conductive electrical charging system
452013027074910/17/13Embedded optics in modular assemblies
462013026019210/03/13Battery pack pressure monitoring system for thermal event detection
472013024144509/19/13Method of operating a dual motor drive and control system for an electric vehicle
482013023464809/12/13Low temperature fast charge
492013022843109/05/13Electrical interface interlock system
502013022191608/29/13Electric vehicle battery lifetime optimization operational mode
512013022192808/29/13Electric vehicle battery lifetime optimization operational mode
522013022191608/29/13Electric vehicle battery lifetime optimization operational mode
532013022192808/29/13Electric vehicle battery lifetime optimization operational mode
542013021157908/15/13Control for automated soldering
552013021157908/15/13Control for automated soldering
562013019618408/01/13Battery module with integrated thermal management system
572013019618408/01/13Battery module with integrated thermal management system
582013018759107/25/13Electric vehicle extended range hybrid battery pack system
592013018759107/25/13Electric vehicle extended range hybrid battery pack system
602013018151107/18/13Electric vehicle extended range hybrid battery pack system
612013018151107/18/13Electric vehicle extended range hybrid battery pack system
622013017901207/11/13Detection of over-current in a battery pack
632013017901207/11/13Detection of over-current in a battery pack
642013015331706/20/13Vehicle battery pack thermal barrier
652013015435206/20/13Pyrotechnic high voltage battery disconnect
662013015331706/20/13Vehicle battery pack thermal barrier
672013015435206/20/13Pyrotechnic high voltage battery disconnect
682013009794004/25/13Method of controlling a dual hinged vehicle door
692013009952304/25/13Dual hinged vehicle door
702013009952404/25/13Control system for use with a dual hinged vehicle door
712013008804404/11/13System for absorbing and distributing side impact energy utilizing an integrated battery pack and side sill assembly
722013008804504/11/13System for absorbing and distributing side impact energy utilizing a side sill assembly with a collapsible sill insert
732013008805104/11/13Sunroof positioning and timing elements
742013008248604/04/13Sunroof mechanism linkage with continuous one part guide track
752013008248704/04/13In-line outer sliding panorama sunroof tracks
762013008248804/04/13Mechanism components integrated into structural sunroof framework
772013008248904/04/13Sunroof utilizing two independent motors
782013007441103/28/13Fuel coupler with wireless port door unlatching actuator
792013007452503/28/13Thermal management system with heat exchanger blending valve
802013007498503/28/13Vehicle port door with wirelessly actuated unlatching assembly
812013007605103/28/13Integrated energy absorbing vehicle crash structure
822013007605903/28/13Charge port door with electromagnetic latching assembly
832013007607603/28/13Angled front hood sealing assembly
\842013007849403/28/13Rigid cell separator for minimizing thermal runaway propagation within a battery
pack
852013007883903/28/13Funnel shaped charge inlet
862013007884103/28/13Electromechanical pawl for controlling vehicle charge inlet access
872013007890003/28/13Air outlet directional flow controller with integrated shut-off door
882013006947603/21/13Rotor design for an electric motor
892013007170103/21/13Response to high voltage electrolysis of coolant in a battery pack
902013007322903/21/13Detection of high voltage electrolysis of coolant in a battery pack
912013007323303/21/13Detection of low voltage electrolysis in a battery pack
922013007323403/21/13Response to low voltage electrolysis in a battery pack
932013006650403/14/13Dual mode range extended electric vehicle
942013006650503/14/13Dual mode range extended electric vehicle
952013006650603/14/13Dual mode range extended electric vehicle
962013005720903/07/13Multiport vehicle dc charging system with variable power distribution
972013005721003/07/13Method of operating a multiport vehicle charging system
982013005918103/07/13Battery cap assembly with high efficiency vent
992013004997102/28/13Battery thermal event detection system utilizing battery pack isolation
monitoring
1002013002704901/31/13Method for determining battery pack isolation resistance via dual bus monitoring
1012013001581401/17/13Charge disruption monitoring and notification system
1022013001582301/17/13Charge rate modulation of metal-air cells as a function of ambient oxygen concentration
1032013000217301/03/13Traction motor controller with dissipation mode
1042013000482001/03/13Battery coolant jacket
1052012031261512/13/12Vehicle battery pack ballistic shield
1062012031551712/13/12Battery pack dehumidifier with active reactivation system
1072012030528312/06/12Power electronics interconnection for electric motor drives
1082012030885712/06/12Method and apparatus for maintaining cell wall integrity using a high yield strength outer
casing1092012030885812/06/12Battery pack enclosure with controlled thermal runaway release
system1102012030885912/06/12Battery pack enclosure with controlled thermal runaway release
system1112012028066211/08/12Charging efficiency using variable isolation
1122012026691410/25/12Cleaning feature for electric charging connector
1132012027008010/25/12Integrated battery pressure relief and terminal isolation system
1142012023780309/20/12Battery pack directed venting system
1152012022909809/13/12Charging efficiency using selectable isolation
1162012023130609/13/12Battery pack venting system
1172012022283309/06/12Active louver system for controlled airflow in a multi-function automotive radiator and condenser
system1182012019411908/02/12Fast switching for power inverter
1192012019507908/02/12Fast switching for power inverter
1202012019508508/02/12Fast switching for power inverter
1212012019508708/02/12Fast switching for power inverter
1222012018099707/19/12Coolant de-aeration reservoir
1232012018381507/19/12Thermal management system with dual mode coolant loops
1242012018382607/19/12Apparatus for the external application of battery pack encapsulant
1252012017589707/12/12Front rail configuration for the front structure of a vehicle
1262012017589807/12/12Bumper mounting plate for double channel front rails
1272012017589907/12/12Front rail reinforcement system
1282012017590007/12/12Dual load path design for a vehicle
1292012017591607/12/12Swept front torque box
1302012016812507/05/12Multi-function automotive radiator and condenser airflow system
1312012016902307/05/12Vehicle front shock tower
1322012016908907/05/12Rear vehicle torque box
1332012016008806/28/12Vehicle battery pack ballistic shield
1342012016058306/28/12Integration system for a vehicle battery pack
1352012016142906/28/12Augmented vehicle seat mount
1362012016143006/28/12Three - cng (compressed natural gas) cylinder mounting device for a vehicle
1372012016147206/28/12System for absorbing and distributing side impact energy utilizing an integrated battery
pack
1382012015184306/21/12Vehicle door secondary sealing system
1392012015367506/21/12Reinforced b-pillar assembly with reinforced rocker joint
1402012015368206/21/12Single piece vehicle rocker panel
1412012015371806/21/12Thermal management system for use with an integrated motor assembly
1422012015390106/21/12Method of withdrawing heat from a battery pack
1432012011144405/10/12Fill port for electric vehicle battery enclosure
1442012011144505/10/12Perforation apparatus and method for electric vehicle battery enclosure
1452012010501505/03/12Battery pack overcharge protection system
1462012009850104/26/12Efficient lead acid battery charging
1472012009195304/19/12Ac current control of mobile battery chargers
1482012004679502/23/12Method and apparatus for extending lifetime for rechargeable stationary energy storage devices
1492012004681502/23/12Method for optimizing battery pack temperature
1502012003731002/16/12Selective cure of adhesive in modular assemblies
1512012003831402/16/12Electric vehicle extended range hybrid battery pack system
1522012004021002/16/12Thermal energy transfer system for a power source utilizing both metal-air and non-metal-air battery packs1532012004021202/16/12Hazard mitigation within a battery pack using metal-air cells
1542012004025302/16/12Collection, storage and use of metal-air battery pack effluent
1552012004025502/16/12Hazard mitigation through gas flow communication between battery packs
1562012004162202/16/12Charge rate modulation of metal-air cells as a function of ambient oxygen concentration
1572012004162302/16/12Charge rate modulation of metal-air cells as a function of ambient oxygen concentration
1582012004162402/16/12Electric vehicle extended range hybrid battery pack system
1592012004162502/16/12Efficient dual source battery pack system for an electric vehicle
602012004162602/16/12Efficient dual source battery pack system for an electric vehicle
1612012004162702/16/12Efficient dual source battery pack system for an electric vehicle
1622012004162802/16/12Control, collection and use of metal-air battery pack effluent
1632012003093202/09/12Method of controlled cell-level fusing within a battery pack
1642012003449702/09/12Battery pack with cell-level fusing
1652012003450102/09/12Battery pack configuration to reduce hazards associated with internal short circuits
1662012002576502/02/12Charge state indicator for an electric vehicle
1672012001919401/26/12Leakage current reduction in combined motor drive and energy storage recharge system
1682012001921201/26/12Bidirectional polyphase multimode converter including boost and buck-boost modes
1692012002125801/26/12Method of controlling system temperature to extend battery pack life
1702012001334101/19/12Method and apparatus for electrically cycling a battery cell to simulate an internal short
1712012000753201/12/12Rotor temperature estimation and motor control torque limiting for vector-controlled ac induction motors
1722011029685512/08/11Thermal management system with dual mode coolant loops
1732011029841712/08/11Methodology for charging batteries safely
1742011026700411/03/11Method of operating a recharging system utilizing a voltage dividing heater
1752011026278310/27/11Battery cell with center pin comprised of an intumescent material
1762011025451210/20/11Trickle charger for high-energy storage systems
1772011021480809/08/11Selective cure of adhesive in modular assemblies
1782011021235609/01/11Extruded and ribbed thermal interface for use with a battery cooling system
1792011020696908/25/11Overmolded thermal interface for use with a battery cooling system
1802011019743108/18/11Manufacturing methods for a triple layer winding pattern
1812011019896008/18/11Dual layer winding pattern and methods of manufacturing same
1822011019896108/18/11Triple layer winding pattern and methods of manufacturing same
1832011019896208/18/11Induction motor lamination design
1842011019896308/18/11Dual layer winding pattern
1852011017455607/21/11Battery pack gas exhaust system
1862011016544607/07/11Corrosion resistant cell mounting well
1872011015664106/30/11State of charge range
1882011015666106/30/11Fast charging with negative ramped current profile
1892011011740305/19/11Battery cell with a center pin comprised of a low melting point material
1902011009176004/21/11System and method for inhibiting the propagation of an exothermic event
1912011008261504/07/11User configurable vehicle user interface
1922011008261604/07/11Vehicle user interface with proximity activation
1932011008261804/07/11Adaptive audible feedback cues for a vehicle user interface
1942011008261904/07/11Adaptive soft buttons for a vehicle user interface
1952011008262004/07/11Adaptive vehicle user interface
1962011008262704/07/11Morphing vehicle user interface
1972011008262804/07/11Cruise control modification
1982011007653803/31/11Method and apparatus for the external application of a battery pack
adhesive
1992011007787903/31/11Determining battery dc impedance
2002011006281903/17/11Rotor design for an electric motor
2012011001256201/20/11Low temperature charging of li-ion cells
2022011001450601/20/11Method and apparatus for maintaining cell wall integrity using a high yield strength outer
sleeve
2032011001451401/20/11Cell with an outer layer of intumescent material
http://https://www.facebook.com/groups/HHOPhilippines20420110003183/01/06/11Common mode voltage enumeration in a battery pack
2052011000443801/06/11Common mode voltage enumeration in a battery pack
2062010031689412/16/10Integrated battery pressure relief and terminal isolation system
2072010031826612/16/10Interface for vehicle function control via a touch screen
2082010030205112/02/10Battery thermal event detection system using a thermally interruptible electrical conductor
2092010027303410/28/10Battery pack enclosure with controlled thermal runaway release system
2102010024461209/30/10Ac motor winding pattern
2112010022295309/02/10Dual motor drive and control system for an electric vehicle
2122010021233808/26/10Battery pack temperature optimization control system
2132010021233908/26/10Intelligent temperature control system for extending battery pack life
2142010018702407/29/10All wheel drive electric vehicle power assist drive system
2152010018790507/29/10All wheel drive electric vehicle power assist drive system
2162010018804307/29/10System for optimizing battery pack cut-off voltage
2172010018804607/29/10Battery cell monitoring and balancing circuit
2182010018804707/29/10Battery cell monitoring and balancing circuit
2192010015130806/17/10Increased resistance to thermal runaway through differential heat transfer
2202010014108006/10/10Induction motor with improved torque density
2212010013302306/03/10All wheel drive electric vehicle power assist drive system
2222010013407306/03/10Battery charging time optimization system
2232010013535506/03/10Battery thermal event detection system using an optical fiber
2242010013638406/03/10Battery thermal event detection system using an electrical conductor with a thermally interruptible insulator
2252010013638506/03/10Method and apparatus for maintaining cell wall integrity during thermal runaway using an outer layer of intumescent material
2262010013638706/03/10Cell cap assembly with recessed terminal and enlarged insulating gasket
2272010013639106/03/10Active thermal runaway mitigation system for use within a battery pack
2282010013639606/03/10Cell separator for minimizing thermal runaway propagation within a battery pack
2292010013640206/03/10Sealed battery enclosure
2302010013640406/03/10Thermal barrier structure for containing thermal runaway propagation within a battery pack
2312010013640706/03/10Battery cell with a partial dielectric barrier for improved battery pack mechanical and thermal performance
2322010013640906/03/10Battery cell with a partial dielectric barrier for improved battery pack mechanical and thermal performance
2332010013641306/03/10Method and apparatus for the external application of battery pack encapsulant
2342010013642106/03/10Cell cap assembly with recessed terminal and enlarged insulating gasket
2352010013642406/03/10Multi-wall battery for maintaining cell wall integrity during thermal runaway
2362010013809206/03/10Battery charging time optimization system
2372010013817806/03/10Battery capacity estimating method and apparatus
2382010010493804/29/10Liquid cooling manifold with multi-function thermal interface
2392010009062904/15/10Flux controlled motor management
2402010008684404/08/10Cell thermal runaway propagation resistance using dual intumescent material layers
2412010007295403/25/10Battery charging time optimization system
2422010007521303/25/10Cell thermal runaway propagation resistant battery pack
2432010007522103/25/10Cell thermal runaway propagation resistance using an internal layer of intumescent
material
2442010002500602/04/10Electric vehicle thermal management system
2452009021274508/27/09Method for battery charging based on cost and life
2462009021668808/27/09System for battery charging based on cost and life
2472009016725407/02/09Multi-mode charging system for an electric vehicle
2482009014069806/04/09Multi-mode charging system for an electric vehicle
2492009014070006/04/09Multi-mode charging system for an electric vehicle
See more HHO Philippines Advanced https://www.facebook.com/groups/HHOPhilippines/Hydrogen On Demand Systemswww.securesupplies.bizThank you Mr Musk and Tesla Motor Team
You have Just unlocked the future
