The 'Infinity' Motor/Generator by Mark & Russ
Forum Administrator
« on April 3rd, 2011, 07:46 AM »Last edited on April 17th, 2011, 09:18 AM by ~Russ/Rwg42985
This is a generator that uses lens law to help it run. It can be improved and this is the first stage of testing. This device it believed to achieve OU if build correctly, I have built it to see how it performs. I have found some ways to improve it already. Keep watching as this unfolds. This is open source project and it must be kept that way. Thanks, Mark & Russ.
Click here to download PDF document for 'The Infinity Motor/Generator'
https://www.youtube.com/watch?v=V-jI8ecXniE
https://www.youtube.com/watch?v=yP7afXo8u-k
simondodd
RE: The 'Infinity' Motor/Generator by Mark & Russ
« Reply #1, on March 14th, 2012, 11:00 AM »
Hey Russ,
Great stuff.
Do you have a circuit diagram for the output of the coils or know where I can get one from...?
I am looking at building something like this in the next couple of weeks and just want to make sure I have everything I need before I start :)
Thanks
Keep up the great work!
Simon
« Reply #2, on March 14th, 2012, 11:03 PM »Last edited on March 14th, 2012, 11:04 PM by ~Russ/Rwg42985
Quote from simondodd on March 14th, 2012, 11:00 AM
Hey Russ,
Great stuff.
Thanks
Simon
hey Simon,
basically its just a half wave bridge rectifier connected to each coil. then a cap after the bridge to help store any energy coming out of the coils.
then the motors are just running all the time.
i have not done any more work on this but i did try bigger magnets and my motors are to small for the bigger magnets.
i have found that this design is not going to work as thought, mainly sense the magnets are running in an arc past the magnets as they spin the other way.  This dose lower the eddy currents but also lowers the out put. a lot!
all in all i would say from my experience that on a small scale its no good. but i did not explore a bigger set up. i also did not do much more than what you see in the videos.
best of luck and hoe this helps!
PS. magnetic cores (iron or steel) may be a big help? right now I'm using no cores...
Tonny
« Reply #3, on May 18th, 2012, 09:11 PM »
Hello My name is Tonny
I am see people projects
That does not really work
 Never a self sufficient motor and said motor and generator infinto need a source
 You remind me of the project that generates energy through a hydrogen fuel cell
 Imagine the cost to bottle the gas and generate power
 There is still much
 And there is a project of a motor function perpetual or infinite that can rotate and generate energy
 Sorry
 The project is a fake
« Reply #4, on May 19th, 2012, 01:08 AM »
Hey guys have you heard of steorn motor,
and have you seen documents and videos from them?
alot got black banned and taken off but they made a huge progress quickly to distrbute in early I got some?
if you need a copy I can link or email
dan
« Reply #5, on May 19th, 2012, 03:05 AM »
Quote from securesupplies on May 19th, 2012, 01:08 AM
dan
I think i have heard of them... but not sure.
« Reply #6, on May 19th, 2012, 05:33 AM »
Quote from Tonny on May 18th, 2012, 09:11 PM
 There is still much
 Sorry
Could you post where you got your information from?:D
Tonny
« Reply #7, on May 19th, 2012, 07:40 PM »
Yes i am go see one movei in you tube okay
https://www.youtube.com/watch?v=HINvta7bnXg
Is one good project
Think, conect one gerator fixo
Conect the axis a as shown altendor which is substituted by a magnet fixed
 Then I comment if it does not work?
 This indeed we are talking about an engine generator infinite, but the consumption is high-speed fall, but still is the best project
 My site work in Brazil www.tectonny.org
 Do not put my projects on the site
 Thank
FloatyBoaty
« Reply #8, on May 19th, 2012, 08:24 PM »
dan
I'd like to get a copy if I could.
Quote from Tonny on May 19th, 2012, 07:40 PM
That's kinda something I was trying to build.  But mine wasn't that great.
« Reply #9, on May 19th, 2012, 09:10 PM »
 There is still much
 Sorry
Lol, it's a consept build... Know one said it would work... ?!?!
Babble
« Reply #11, on October 11th, 2012, 08:45 PM »
The reason the individual magnets work is that you need a changing magnetic field to generate electricity.  As the small magnets are spinning due to the motors they pass the coils  and vary the flux level which then (when shorted) generates a reverse field that pushes the magnet away.  This force causes rotation of the main wheel and shaft.  When you changed the magnets to solid rings or disks there is no magnetic flux change so the effect stopped.  I do admire your construction ability but there is no electrical device that will produce over unity.   Also remember that a device needs to do more than just spin on its bearings which takes very little force.
« Reply #12, on October 11th, 2012, 10:46 PM »Last edited on October 11th, 2012, 10:51 PM by FaradayEZ
Quote from Babble on October 11th, 2012, 08:45 PM
I agree with babble, if the use of these devices is to show what induction is or does then that's fine and has succeeded.
But like with the EPG system i think it is chasing ghosts to trial and error you're way into overunity.
If you want to outrun or trick induction then you have to know at what speed and what voltage the induction works, and have to make sure that the next magnet hits it at the right time and that the induction in between doesn't effect the force acting on it.
So you need a mathematical 3d model and calculate the whole lot, and do tests on how fast induction is with every different voltage..
And even then you still have to find a way to get the amps out of it, volts is easier, like with bedini.
edwardthefma
« Reply #13, on December 26th, 2013, 02:15 PM »
link for the  PDF document for 'The Infinity Motor/Generator' is down can you re upload it i suggest using Google drive since you get 15 gigabytes of storage for free and google isin't going anywhere if this project dose as it clames it could turn our world upside down
and be the savior that saves the USA from financial ruin
« Reply #14, on December 27th, 2013, 02:52 AM »
Quote from edwardthefma on December 26th, 2013, 02:15 PM
Try this for now, http://www.google.se/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CC8QFjAA&url=http%3A%2F%2Fwww.overunity.com%2F3842%2Fmuller-dynamo%2Fdlattach%2Fattach%2F53613%2F&ei=oVq9Uo_kAaqS4ASEuYHYBg&usg=AFQjCNEaMmc4OVAmgqbAqAVvLVxBP3vRlA&bvm=bv.58187178,d.bGE
I'll ask Russ ro reup it, thanks for the heads up
