BlackLight Power Inc. Announces Sustained Production of an Enormous Amount of El
any one know anything about this?
seems interesting. using the water to make light from plasma to run photocells.
hummm..
thoughts guys?
maybe i'm behind on this but i'm positing it here to see your thoughts?
http://campaign.r20.constantcontact.com/render?ca=5c2b1e44-bd26-4523-9e61-09a318e3b51d&c=41cbf9c0-b435-11e3-8e74-d4ae527599c4&ch=42c722a0-b435-11e3-9002-d4ae527599c4
thx1138v2
Re: BlackLight Power Inc. Announces Sustained Production of an Enormous Amount of El
« Reply #3, on April 4th, 2014, 04:24 PM »
There's not anything at that link but a request for donations from newenergy movement which appears to be some third party group.
Search for "BlackLight Power Inc" turns up a lot of hits.
It appears the inventor has developed a process to use "hydrinos" whatever that is. Lots of naysayers and positive reviews both, the latest of which I saw was in January this year. It seems the more positive reviews are by people who have money invested in the company. Duh!
I didn't turn up any pictures of the internal workings of the device but it sounds like they are using sonoluminescense or something similar to create light from water and use the light to power photovoltaic cells. This may be sonoluminescense or a LENR process. If LENR then it's going to rely on a catalyst of some sort and, no doubt, that will be their control and profit point. Sounds a lot like E-CAT.
A critical analysis of the hydrino model
It seems to be a new model of chemistry but there actually may be something to that.
Chemists merge experimentation with theory in understanding of water molecule
New salt compounds challenge the foundation of chemistry
Persuading light to mix it up with matter
My cynicism is showing through but search "sonoluminescense". It's real enough.
I considered doing something similar with tritium. Tritium is used to make light bulbs that require no power for stairways in office buildings. It's a type of emergency lighting for the stairways and it will light for several years and there is no on/off. It's always on. Low energy density is the problem with the idea I had of combining it with photovoltaics.
Peter v Noorden wrote:
Blacklight has increased the kinetics of the hydrino reaction enormously by running a very short (1 msec) and very high current ( 10000 A) pulse through a solution of water and for instance Cu CuO. About 25-50% of the hydrogen present is transfered into H1/4.
The energy release is 50MJ/mol H2 when all H2 is transformed to (H1/4)2
The significance of the solarcel demo is not trivial:
We all know that X rays, gamma rays or light coming from e.g fire crackers (which is mainly infrared) can not be efficiently used to produce electricity by using commercial solar cells.
The blacklight SF-CIHT reaction produces a lot of visible bright light with the same spectrum of light coming from the solar corona.
This is not coincidental bcs it is very likely that the by black light power discovered reaction is the same reaction which takes place in the solar corona which is responsible for the unexplained high temperature.
The energy of the SF-CIHT cell is released by kinetic energy and photons.
The produced plasma can be used to produce electricity by a MHD reactor.
The photons can be transformed to electricity with a efficiency of 15-20% in commercial solar cells. Multilayer solar cells will be even better with a efficiency of 30-40%.
Jones Beene responds, a person following BLP for 20 years  wrote:
How is this Rube Goldberg seam-welder anything less than a spectacular
 admission of failure of the two most recent promised devices ?
 Or worse - a fraud on potential investors?
 Mills neglects to mention last year's over-hyped versions of the CHIT- the
 stacked pan-plate version and the MHD version. Of course, they did not work
 well and must have been abandoned ... and then, to gloss over that little
 problem, he fabricates a more grandiose version with the implication that is
 so great the others had to wait.
 Just like the half dozen prior over-hyped versions, the "solid fuel
 reactor," the reverse gyrotron, the hydrino battery, the Capstone turbine,
 etc, etc ... none of which worked well enough to follow up on. And what
 about all those Utility companies out there waiting for their promised
 gigawatts? Mills is playing his investors as fools.
 Geeze, should they not call this beefed-up version the "Bull-CHIT" ...?
Axil Wrote:
BlackLight Power is about to be swept into the dustbin of history. In a year or less, a workable LENR product will be demonstrated as a preproduction prototype. This should cut the legs out from under  their investor base who have been so cruelly abused  over these many years and that has propped up the BLP fantasy for far too long.
The clock is ticking, their time is short, their fate is set, and their end is near. As an anathema to the quantum world, the fantasy that is the hydrino will be a fiction of the past and forgotten as the wondrous quantum causes of LENR are patently explained by serious and innovative scientific methods and top-notch research.
« Reply #6, on April 5th, 2014, 12:26 AM »
Axil, before LENR takes-off in full furry, is there anything to some of the latest experiments with NMR?  People studying the NMR phenomena declare the reactive material as fuel, which got me thinking...  Just how similar at the core is NMR and LENR?  Do you suppose there is more than just a link here?  Maybe it is actually the same thing?
Axil
« Reply #7, on April 5th, 2014, 05:55 PM »Last edited on April 5th, 2014, 06:09 PM
Quote from Matt Watts on April 5th, 2014, 12:26 AM
If you mean NMR as Nuclear Magnetic Resonance, then you are right in general, but the devil is in the details and there are tons of details. Let us talk about some of the more important details here below.
A magnetic field is the cause for the fusion of nuclei, but it is not the very weak magnetic fields seen in MRIs. These weak fields are only in the single digits in tesla strength. The magnetic fields seen in the nickel/hydrogen LENR reactor get up to 10^16 (1,000,000,000,000,000) tesla at the atomic scale. DGT has reported a magnetic field of 1.6 tesla at a distance of 20 centimeters from the reaction volume. Now that is an amazing field strength when all the Ni/H reactor is doing in heating up a pile of nickel dust. That 10^16 teals is about as strong a magnetic field as you will see anywhere in the universe, far bigger than any black hole or neutron star can produce.
The set of mechanisms whereby the magnetic field interacts with the vacuum and the nucleus is many faceted, complex, obscure, uncorrelated and hard to understand.
Let me give you a taste for example, results from the Large Hadron Collider show asymmetries because of magnetic effects: CP violations.
CP_violation
Heavy ion collisions show these large magnetic effects during the formation of the quark-gluon plasma
The Chiral Magnetic Effect and Anomaly-Induced Transport
Abstract
The Chiral Magnetic Effect (CME) is the phenomenon of electric charge separation along the external magnetic field that is induced by the chirality imbalance. The CME is a macroscopic quantum effect - it is a manifestation of the chiral anomaly creating a collective motion in Dirac sea. Because the chirality imbalance is related to the global topology of gauge fields, the CME current is topologically protected and hence non-dissipative even in the presence of strong interactions. As a result, the CME and related quantum phenomena affect the hydrodynamical and transport behavior of systems possessing chiral fermions, from the quark-gluon plasma to chiral materials.
The goal of the present review is to provide an elementary introduction into the main ideas underlying the physics of CME, a historical perspective, and a guide to the rapidly growing literature on this topic.
There is a lot of work being done by astrophysicists in the area of nuclear reactions on the surface of neutron stars and black holes involving high magnetic fields. There seems to be a threshold value of 10^16 Tesla involved for vacuum breakdown where the most intense magnetic effects take hold
How is this huge magnetic field produced?
The Ni/H reactor design allows for a huge amplification factor of dipole charge separation and EMF concentration, produced by many nanoparticles forming a particle aggregation.
An important problem in ’plasmonics’ is the question of how a collection of micro and nano particles should be designed and arranged with respect to each other to produce the strongest possible EMF field enhancement.
The micro particle
To build a great LENR reactor, you need to fabricate a great primary micro particle: the backbone of your system; you need a 5 micron micro particle dressed out completely with nano-hair.
Such a particle looks like a sea urchin or if your were a star trek fan, a tribble
The industry standard name for this type of particle is an “inorganic particle”.
The nanoparticle formula for this type of particle that has already been developed is TM6CyHz, where TM is transition metal (molybdenum, tungsten, tantalum, niobium), C is chalcogen (sulfur, selenium, tellurium), H is halogen (iodine).
Some of the elements that this particle is made of is low temperature and won't hold up to the high heat that LENR can produce.
To use the high heat and the associated thermodynamic efficiency that go along with it you need to use top of the line refractory elements.
So for the ideal micro-particle, I like a Tungsten micro particle body with a silicon carbide nanowire substrate covering and then an outer sprinkling of nanowire outer coating of tungsten through vapor disposition. We can't do better than that.
If I were in the W/H (W for tungsten) reactor building business, I would submit the specification for the fabrication of this particle to these venders
http://www.nanochemistry.it/NPsuppliers.html
I would hope that one of these vendors could meet the challenge to build the best.
If you want to take on this task as the dominant builder of the best LENR reactor around, I encourage you to be the best that you can be.
Next, the nanoparticle aggregation
A  solution to this problem used in the Ni/H reactor is the configuration of a self-similar chain of particles with decreasing diameters
K. Li, M. I. Stockman, and D. J. Bergman.Self-similar chain of metal nanospheres as an efficient nanolens.Phys. Rev. Lett. 91, 227402 (2003).
Self-similarity requires that radii Ri and the distances di,i+1 of the spheres i and i+1 are connected by the simple relations Ri+1 = •Ri and di+1,i+2 = •kdi,i+1 where • k<< 1. The last condition ensures that the field of a given nanoparticle is only a weak perturbation of the previous, bigger particle. The self-similarity is not a necessary condition but it allows for an elegant notation. All particles are considered in the electrostatic limit.
Now, if each of the particles enhances its driving field by a certain factor (a), then the cumulative effect of the chain of particles is a field enhancement on the order of (a)n where n is the number of particles. In other words, the enhanced field of the largest particle acts as an excitation field for the next smaller particle. The resulting enhanced field of this second particle then acts as the excitation field for the next smaller particle, and so on. For the system depicted in Fig. 12.23 of
Chapter 12 - Surface plasmons
assuming a moderate a » 10, leads to a total field enhancement of »1000 (every factor of 10 particles produces an enhancement of 1000 or 10 to the power of 3). As we will see in the following section, field enhancements of at least 1000 are necessary to observe the Raman scattering of single molecules adsorbed onto rough metal structures.
Assume the largest particle is 7*10^^-6 (7 microns) and the smallest is a nanometer or 10^^-9 , then the size difference  is 1.4 * 10^^4
 There is a particle size amplification of about 10000. If there are 10,000 nanoparticles in the chain, there will be 1000 to the power of 3 particle enhancement factor or 1,000,000,000.
That is a total enhancement factor of 10,000,000,000,000.  Add the million amp nanowire enhancement at the tip of the nanowire hair covering of a micro particle in with the particle number/size enhancement in a pile of nano-particles and you get a big number.
