I have a new project that I'm about to venture into. I'm going to build an HHO station, basically a box to supplement my fuel requirements on my pickup truck. My idea is to place the cell, reservoir, bubbler and flash suppressors in the bed of my truck. The cell is a 59 plate unit and I would prefer to run it from high voltage like I have done in the past in my garage. The problem I'm running into is wiring. I don't want to run 000 wire from my batteries all the way back to the bed of the truck. So I'm thinking if a can find a decent 2000 watt modified sine wave inverter and connect that to the battery right under the hood, the majority of my issues will be solved. What I don't know is if there are any relatively inexpensive inverters out there that are hardened enough to handle the environmental conditions that would be found under the hood of vehicle--temperature and road spray being the two most critical. Here's a fairly popular inverter for starters:
http://site.invertersrus.com/pdf/pro1200to3000wm.pdf
Do you think this unit could be sealed with some sort of air filter on the cooling intake? Or are there other comparable inverters out there that are already ruggedized enough for this sort of duty?
I see items like these out there:
But they are just too far out of my price range to consider.
For my application, a simple high amperage DC to DC converter would be ideal, but those all seem to be even more expensive.
Anyway, if someone has done this or knows of a good device, please post a reply. Much appreciate it.
