Hmm cool this looks like a good read, I'll look into it... right now im trying to make a DIY tachometer, I'm going to try using an old optical mouse sensor a laser pointer and a reflective point on the spinning device, should be able to get an idea of it more light = faster less = slower right? Makes sense... anway gotta eat been starving myself lately cuz ive been working and researching this so much then I'm going to try setting that up.
So far with the sample size I have been using a stop watch to measure how long it spins for when I spin it the results are as follows...
Ok so far The Control group values meaning the motor with nothing done to it
spun an average of 128.9 (sample size = 36)
Then if I took my idea and put it in the reversed configuration it spun
an average of 82.1 (Sample size = 12)
Then with the configuration working with the motor
I got an average of 141.4166666666 or so... (Sample size 12)
So according to that while its sort of.. uh not very scientific and I was spinning it with my hand as fast as I could with the stop watch right next to the motor so I could start and stop it as quickly as possible while spinning it the results are a little dodgy still I need an extra person to run the stop watch for me, but all in all according to these results my configuration reversed Definitely slows it down u reversed it seems to be helping the motor spin but I need to take a larger sample size of that still. It seems to get about 10-14 points above the control group though which seems like a positive result...
:)The best part is the simplicity of these configurations... like seriously lol... its commical and beautiful at the same time if its really this simple.
So Control = 128.9
Magnetic influence = 141.416
Negative Magnetic Influence = 82.1
I'm so happy with that right now haha...
Its also so much better than the other method, the other method is too costly (well not that bad) but it requires sooo many more magnets and the results are minimal, this however is amazing... if I add enough magnets to it in this configuration the motor just might spin itself.
Wish me luck... lol
UPDATE
Ok this time I did it differently instead of spinning it as fast as I could and seeing which spins longer i made it easier for me and my hand by just doing a regular spin...
The sample size is 21 no magnets and 21 with a positive magnetic configuration.
The results are
No magnets = avg 97.1
With magnets = 107.1
So its like a 3% increase in efficiency so far, but thats with barely using any magnets in the configuration.
I think if done right with enough magnets it will spin on its own...
UPDATE 2
Alright I got a better configuration now...
Avg 127 with just averagely spinning it compared to averagely spinning it with no magnets which gets about a 97.1...
Now im going to spin it with no magnets fast as i can and average that and compare to that average of 127... about a 23% increase in spin time or a 23% decrease in the motors physical resistance..
I might not have the right supplies to get this to spin on its own... its very sensitive it may require machining neodymium magnets to specific sizes, maybe theres a way to calculate it though to sort of get it exact so its all balanced enough and it will spin on its own, might be able to calculate it actually based on magnetic field strengths and coil length and howmuch of each material is being used
etc... so when i try to add anything to this it seems to lose momentum i think because i cannot add or subtract the correct amount of magnetic force to the device... but the closer i get to balancing all the forces it seems the higher that efficiency increases... like... from 107 to 127... by just adding a miniature disc magnet is pretty good... from 3% increase to a 23%... 20% more efficient just by adding a small disc magnet...
edit ok... finally got my volt meter to register amps... going to do the same tests above with that and see which gets higher amps.
Posted: September 16th, 2014, 11:11 AM
http://open-source-energy.org/?topic=2153.msg29132#msg29132Ok so I quickly retracted my video of a semi working experimental version of this idea because of Morale and Ethical reasons of too much energy falling into the hands of big business to further keep us below them.... but however I will post my scientific findings that you guys can probably make more sense of that than them anyways.
Plus if this is combined with the Back EMF generator ideas the two combined might get us some serious results here.
Plus add in the TPU effect?
