Laughing all the way to the bank part two
nav
« on January 8th, 2014, 12:15 PM »Last edited on January 8th, 2014, 12:49 PM by nav
This is probably going to be the most important Stan Meyer thread you'll ever read, cut and paste it to other websites as much as you can just in case this gets shut down.
Look at the schematic and Meyer's Unipolar magnetic field coupling. Look at the direction of the field created by it, its perpendicular to the flux direction. Forget how Meyer describes his resonant charging chokes, they are electromagnets to shut down back EMF and are marked as such on the schematic except in name.
http://en.wikipedia.org/wiki/File:Simple_electromagnet2.gif
[attachment=4918]
Firstly, we now know that Meyer is using magnets to influence flux paths but the type of magnet and the way you manipulate it is very important.
His VIC is now much more simple to understand, A primary with an input of pulsed DC, a secondary and two electromagnets separated by the load. Nothing more, nothing less. The diode simply makes sure the electromagnets are polarized in the right direction to stop the back EMF. ITS THAT SIMPLE.
The frequency of the pulsed and gated DC and the voltage are only to time the actions of the electromagnets with the rest of the circuitry.
Forget the wording in which Stan Meyer describes his schematics, its all BS so he can register patents and lock down the designs, he couldn't patent electromagnets, he couldn't patent basic transformers either so he just makes silly names up for them all.
The electromagnets may well have resonance but they are still electromagnets.
Jesus you could even use your own electromagnets with their own power supply to remove back EMF in ANY transformer circuit and time them to the pulsed DC.
Go play.
Oh and by the way, you will probably have problems with core saturation with the electromagnets so here's some advice: Use efficient core materials and provide a way of restricting the saturation such as a gating system on your pulse width;)
I wonder how many people have been building this schematic and saturating the core so it doesn't work? Everybody is my guess.
nav
RE: Laughing all the way to the bank part two
« Reply #1, on January 8th, 2014, 01:25 PM »
You can also control the flux saturation in the core by the resistive load across the two electromagnets and the windings on the them and so on. Notice he is monitoring the core and nothing else on that schematic. He's does that so he can monitor for over saturation of the core then link that to a phase lock loop which controls the pulse width and gating, lowering and increasing the PWM timing so he's just below saturation 100% of the time. It's absolutely ingenious.
« Reply #2, on January 8th, 2014, 04:37 PM »Last edited on January 8th, 2014, 04:38 PM by Matt Watts
So let me ask you nav, when Stan says he is reducing amps, that's only true on the input side correct?  There is still plenty of amperage on the output side.
This all looks way too easy.  Get yourself two C-cores, put the coils on there and begin working your way up with larger and larger bar magnets across the two sides until you hit a spot that's mostly in-tune with your load.
This looks a lot like Tom Bearden's MEG to me.  If that's the case, you'll probably want to use a nano-crystalline core, though I suspect an Amorphous C-Core may also work.
« Reply #3, on January 8th, 2014, 05:40 PM »
I think amps are still supposed to be restricted to the cell.  Otherwise it won't run cool, compared to electrolysis.  I'm still not picturing how the choke coils will behave the same as magnets when they are powered by the secondary coil?  Seems like they should turn "on" at the falling edge of the secondary instead.
nav
« Reply #5, on January 9th, 2014, 11:23 AM »
Quote from Matt Watts on January 8th, 2014, 04:37 PM
We don't know till we get into the nitty gritty and start to monitor temperature and current and find how whats going on here. We know Stan's cell is cool, we also know that Tesla created a type of Electricity that wasn't dangerous to the touch and ran cold in comparison with conventional current, it has been described as cold Electricity. We are thinking along the lines of Electricity on the secondary side that IS NOT using current at all and that conventional current is the enemy.
I'm not familiar with Bearden's meg and its workings so i don't know. All I am saying is that Meyer, in order to get patents changed the names of conventional components and has been a little bit naughty which has cost people a lot of time and money. If we would have known he was using electromagnets to stop back EMF and cut off the current from the primary 20 years ago, the world would be a very different place by now.
Breakzeitgeist
« Reply #6, on January 9th, 2014, 02:47 PM »Last edited on January 9th, 2014, 02:58 PM by Breakzeitgeist
/watch?v=-zMEUY80Auk&feature=c4-overview&list=UU0ZPFzU6n0cDGXTB0XT3vRQ
this is dielectricity im transmitting on 30 thousands of an in. wire size of a human hair and lighting 300 watt bulb it reaches 200 degrees in 30 sec and the current can run right trough me see this one i let 10,000 volts plus right into my body and its so awesome /watch?v=GzH5GU2IT6g
so im about to run experiment as i type this so vid will be up shortly but i will be using the rotery spark gap and replacing door knob caps with wate ful cells. remember this is dielectricity meaning it comes from the dielectric ralm and theres 5 forms of it and it all looks diffrent and yes i agree its all connected and my inner guide has been leading me to the answers so i keep listing and thinking with my heart and not my head. I have no idea if any of it will work. most everything I do is just guess work. The only thing i know for sure is that its coming from the inner me....free energy
« Reply #7, on January 9th, 2014, 03:10 PM »
Quote from Breakzeitgeist on January 9th, 2014, 02:47 PM
this is dielectricity im transmitting on 30 thousands of an in. wire size of a human hair and lighting 300 watt bulb it reaches 200 degrees in 30 sec and the current can run right trough me see this one i let 10,000 volts plus right into my body and its so awesome https://www.youtube.com/watch?v=GzH5GU2IT6g
That has got to be one of the coolest things I have ever seen, but we got to get you a tripod for your camera.  :P
So what happens when you put this form of electricity through water?
Breakzeitgeist
« Reply #8, on January 9th, 2014, 03:54 PM »
im about to post a vid and show you can drop a light in water and put hands in and no shock...but what im interested in is replacing the door knob caps with the fuel cell or cells you need 2 caps but check out all my vids i show how we close the loop using the electron extraction circuit. Stan whole system is a symbeotic system. anyways the most important thing stan says to me is that atoms poses intellengence....also after seeing my vids you will see that we still have so much to learn. all of us and for the educated ones out there no offense but the bad guys have been misleading people for a long time. the whole world.....The truth can only befound by going all the way back and reading all things Tesla, Heavyside and stinmetz and Eric dollard...anyways look i dont really talk much but if you want to know anything i will tell you what I know. I want to help and i want to win and share it with the world. Im about to post vid soon of a method to reduce your power consumtion from the grid using what most of us already have but im still varifing that its real and then i show ya how you can to...ok so peace to you all I am because we are!!!
