This is gonna make you laugh because its so simple its ridiculous. I've always said to my good friend who I have spent years talking about this subject with, that if I ever drop on something then its going out into the big bad world right away and I'm gonna keep that promise.
Recently I've been going through schematics of Tesla and Meyer and I've been pondering this schematic of Meyer:
[attachment=4879]
...and to be honest its been bugging me for months what the Unipolar magnetic field coupling is on that schematic. Now I went and got the Canadian patent and was still a little baffled by it all so I started to wonder about influencing flux paths in magnetic cores and who had experience in that field and it turned out a fellow by the name of Charles Flynn had patented several devices. Mainly, increases in voltage and co-efficiency were his game and it turned out that he used magnets to influence, cut off and re-route magnetic flux paths in transformers.
Obviously Bi-toroid transformers try to achieve the same goal but instead of using magnets they work by a combination of increasing and decreasing the resistive path of magnetic flux in favour of over unity but with limitations.
I have mentioned that I felt Meyer's work and Bi-Toroids have something in common in previous posts BTW and I have been working on that.
So......here's the money shot, I got it in my head that Meyer was using magnets to influence his VIC and that his Unipolar magnetic field coupling was none other than a straight forward run of the mill bar magnet.
I built a fully operational HHO front end about six months ago and had recently blown a NEC555 timer chip and two days since I replaced the chip with a new one. My front end device allows me to use any frequency from 0-20Khz using the NEC555 and then gate it with another PWM at anywhere between 0-13.8 vdc, which is connected to an optocoupler/transister configuration, that allows me up to 5 amps load without stressing the PWM's.
So I strapped a bog standard step up transformer to my front end and a 12-18vdc heavy duty relay out the back of the transformer. I think the transformer is 1:4 in voltage but I wasn't sure so i kept the output pulses out of my front end wide apart and kept the output voltage of the transformer less than 18 vdc.
Got a magnet and did what Flynn did.
Holy crap! Thats all I can say. All I kept saying to myself was no no no no no no no no no no no it can't be that simple. But it is.
No voltage increase but the amps more than halved as soon as I stuck it next to the iron core of the transformer. If you put it the other way so the poles are reversed on the magnet my power supply started buzzing, the amps doubled and the relay slowed down as if the EMF increased. There is no other explanation, the magnet only allows flux to travel in one direction depending on the way you place it on the core.
You have to be careful because you can saturate the core so don't use massive magnets, start off with little ones till you reach probably 80% of the saturation point.
Now, here's the important bit for all you Meyer fans: If you are using resonant coils then the Q factor is gonna be in orbit, the efficiency of this set up in resonant coils is going to go bananas without any shadow of a doubt.
Anyway, did a search on You-tube and i'm not the first to suss this out, obviously Flynn did it but a young man demonstrates it quite well here:-
https://www.youtube.com/watch?v=r8asKJNYJIY
Now if I can do what i did just messing about, imagine what you can do with magnets tuned to your transformer more efficiently? Imagine what the efficiency of resonant coils is going to be and the Q factor?
Message to Stan Meyer God bless his soul: Unipolar magnetic field coupling? Thats the best description I've ever heard for a bar magnet, you crafty old devil.
Crack on members, crack on.........the cats out the bag.
[attachment=4879]
