One of the biggest drawbacks of wind and solar is that they are both intermittent and hence highly variable and although in theory power can be shunted from an area enjoying a surplus to an area with a deficit, in practice this is not as easy as it sounds. Since the one thing that a power station cannot do is provide more power than it generates, it is necessary to ‘balance’ renewable inputs to the grid by keeping on standby conventional power sources. What this means is that instead of renewable power integrated into the grid being “free” it is in fact being compensated by standby conventional power sources, so the tremendous financial gains that should accrue from using renewables is largely mythical and in fact is more often than not negative. The converse is also true, often renewables integrating into the grid supply more energy than the grid can use ! The problem then becomes one of how to dump that extra power, you can’t for instance just put it into the ground, there will be a lot more deaths from spontaneous combustion than exist at present! Nor can you let it out into the Ocean, a lot of fish will die. So when you have to shed several Megawatts of power in a matter of seconds it becomes a problem. As Long Beach Mayor Bob Foster, a board member of the California grid system management commented, “We are getting to the point where we will have to pay people not to produce power.”
Energy from wind and solar is essentially free energy, unfortunately due to the presence of intermittency and problems arising from trying to balance the load, renewable energy is often more costly than energy generated by fossil fuel alone. More and more money is being pumped into wind and solar; money is not going to make the sun shine at night nor will it make the wind blow on command. Money CAN, however, help with NEW approaches that use OTHER naturally occurring forces of nature such as Gravity and atmospheric pressure. The weight of the many miles of air above us in the atmosphere is as tangible a force of nature as the wind or the sun. The force exerted by gravity is familiar to everyone. No-one has tried to utilise these forces of nature, we at Green Initiative did try and we have succeeded with ‘Home Grid’. The system caters to almost every possible energy need from individual houses to multi-storey high rise buildings. It is equally at home in an urban as a rural environment.
‘Home Grid’ uses atmospheric pressure and gravity to create a continuous cycle that can be used to generate electricity. ‘Home Grid’ works in the manner of the Newcomen Atmospheric engine, however instead of condensing steam to create a vacuum, ‘Home Grid’ uses the kinetic energy of a descending counterweight to turn an alternator that produces electricity that is fed to a vacuum turbine. More details of how this system works can be found at : http://igg.me/p/597849 it is almost 90% certain that ‘Home Grid’ will work. ‘ Home Grid’ is essentially twenty first century technology used to run well proven 19th. century designs at maximum efficiency, the results are surprising. No fossil fuels are necessary, ‘Home Grid’ is 100% clean.
More to follow in next post: detailed description
