4) .5 tsp Organic Soy Lecithin Granules
OR
4) 2-3 Drops of Prepared Sunflower Lecithin
The Sunflower Lecithin is a vital ingredient for this healing remedy. Here is where to get it and what to do with it.
Bluemountainorganics.com Raw Sunflower Lecithin
-The Sunflower Lecithin comes in a syrup consistency, so it needs to be blended with some water first.
-Put 1 Tbsp Sunflower Lecithin Syrup into 1 Cup of Room temperature Water. Do not shock the Sunflower Lecithin by going from cold to hot.
-Place this mixture in a double boiler setup keeping the temperature under 42 Dec Celsius.
-Use an Immersion Blender to mix the two together until it makes a yellow liquid with no chunks of syrup. A large mouth mason jar fits my Immersion Blender perfectly. The mixture will foam up a lot when blending, so do not try to fit two batches into one mason jar, I tried.
-If you only have a blender, it will work as well. heat water to under 35-40 Dec Celsius. Blend on Low.
-Allow mixture to rest at room temperature, then refrigerate when cool.
•Lecithin allows the nutrients to easily absorb threw the small intestine walls.
•Lecithin delivers Oils and Fats into Cells.
•The brain is about 70% Lipids. and about 35% of that being Omega 3.
•Lecithin is present in every cell of the body.
•Lecithin dissolves unhealthy fats in the body as well as arterial plaque.
OR
