taking what was learned from all the posts in this forum i add the most basic principles, and patents.
all in one easy to find thread. no need to add much, unless the terms can be united.
cheers.
when i have time i will edit the thread, and i hope you will find it much more satisfactory in locating information on the Net for, Water Fuel Cell, Ion Chambers, Epg systems. At RwgReasearch.com.
add 3 water patents, add 2 epg patent, add info on plasma ion chambers.
add what ever it take so we see these results in a short time..
:cool::cool:from Stanley Meyer 1993 International Symposium on Energy Colorado find on youtube, link >>>>>. link to 1993 INT. Symposium.<<<<<
Code: [Select] :D
Its a bias of sorts... this is what bias does. wiki. link>>>>Wiki link Bias <<<<
This next link is included as a interesting link on the triode valve . It may be of use. http://www.scribd.com/doc/14804996/The-Triode-Valve
below, in a clip outlined in blue text, i include what Tesla describes as a means for raising a gas to a higher energy state. meaning above ground staet. for use in a epg as a magnetic fluid under pressure.:heart: The patent labeled second Epg give a good theory behind the process of moving magnetic fluids.
/watch?v=sWei054SSf0
i thought i would add this as one alternative means of thinking., i got the idea for my first water cell from watching a few of his you tube movies. nickle coating on plates may allow for use of cheaper materials over stainless..
click this link to get a feel for primary secondary functions transformer.
/watch?v=79VEaV5jOE4
If i Bias note how we can use dis similar coils, and drive them separately. like primary, and secondary coils on two drivers. pulse time magnitude, duration. the idea comes in handy.
add paint. Add Tesla on ions with tension. electron beams. crooks tube function . voltage spark gaps.
cheers.
Mechanic Wrote:
Tanks Adys....!!
One more thing I just noticed, and would like confirmation on, that after watching the '93 lecture Stanley explain, through the Grace of God and how I under stood it, that when you reach full voltage potential, maximum voltage amplitude, you switch off "5 seconds" and then by switching on again you create resonant action... because when you switch off you can produce gas for 94 seconds while the voltage potential drop and therefore when you switch on again after that "5 seconds" the gas process starts off at a higher rate causing more gas production and therefore entering a resonant gas production rate and by repeating this on/off process you reach maximum applied voltage through now n step charged effect to maximum applied voltage or until the full flow rate of water into the now resonant cavity is achieved.....
Do I have this correct or am I missing something here????
Please reply with input if I'm not correct in my understanding of his explanation!!!!
Thanks
Freethisone wrote very good work. this is what um i? been saying all along Its a bias. I uploaded at least 2 patent on this that do the same thing. now the theory is its a bias, but in your case you are the first to make any type of acknowledgment. by your graze you have the answer that puzzled everyone all this time. I don't understand how it could have been keep a secret so long considering all the patents that refer to it. add.
i will locate all these patents they are scattered all over the place so people can see them easyIts a bias of sorts... this is what bias does. wiki. link>>>>Wiki link Bias <<<<
