Stan mentions multiple times in his writings the convenience of not just controlling the pulse width but also the "voltage amplitude"
Now in Stans info we find references to "variable voltage amplitude" yet it’s usually in fixed positions in his diagrams. (Selector switch, or variac manual control etc).
What do you guys think of trying to apply a varying voltage during a repetitive pulse train?
Usually we only apply a fixed voltage pulse. And if we get it right this charges the cell.
Now imagine a step increasing voltage amplitude pulse. During step charging our cell. Acording to stan it should enhance the polarization process.
Let me know what you guys think, should i follow this rabbit?
In the video bellow I attempt to explain how to achieve this electronically using a
sequential circuit to trigger multiple SCR gates sequentially during repetitive pulse trains.
/watch?v=99V-kr_8zio&feature=c4-overview&list=UU095jfI446MK9VoLnAJKwRw
That's good information. Thanks!
I also want to note that Attenuating means "lowering". So Stanley was evidently specifically implying that one should start with higher voltage and work their way down. This is confirmed by the second sentence wherein he speaks of obtaining "an even higher gas-yield (88) at maximum voltage deflection (xxx Vn)."
As a sample below, I hope that it might be possible for me to do something like this below to make Stan's document easier to review and understand.
Try all the links and let me know what you think. Just pay attention to the numbers on the images to see what you looking for.
From the book The Birth of New Technology - S.Meyer:
By attenuating voltage amplitude (Vo xxx Vn) in conjunction with pulse-width (65a xxx 65n) allows voltage intensifier circuit (190) of Figure (3-23) to tune-in and match the resonant characteristics or resonant frequency of water bath (91) since water bath (91) always maintains its dielectric properties during pulsing operations. At resonance, electrical polarization process (160) interacts uniformly with liberated charged particles (92/95) of Figure (3-25) to obtain an even higher gas-yield (88) at maximum voltage deflection (xxx Vn). The established resonant frequency is most generally in the audio range from 1 Khz up to and beyond 10 Khz and is dependent upon the amount of contaminants in natural water. Oscillating and superimposing electrical charged particles unto the Electrical Polarization process at a given pulse-frequency is, now, herein called "Resonant Action", as illustrated in (240) of Figure (3-25).
Enjoy!
Mogir
Thanks for the info on attenuation. it’s amazing how many times I find myself going back to these paragraphs over and over and finding out new stuff. I must have read his book half a dozen times by know.
And yes its very meticulous process reading a technical book like Stans. I also find my Self re-checking his reference numbers on illustrations constantly it’s very frustrating but I believe that to come to a full understanding its crucial.
I'm understanding Stanley's reasoning behind this a little better now after seeing this post by freethisone:
http://open-source-energy.org/?tid=321&pid=20991#pid20991
So, After a high voltage exposure the water molecules in the chamber will polarize as respects their magnetic alignment in relation to the cathode and the anode. This polarization remains momentarily even after the voltage is droped. THIS state IS the BIAS LINE for phase transition to plasma, which can be pushed and maintained by oscillating and superimposing additional electrical charged particles at a certain pulse-frequency, but without maintaining as high of a voltage as at first.
Mogir
you have it down very well. im so glad you are able to make it so clear.Thank you.
:)in saying then is it obvious to have 1 high voltage transformer, and power supply pulse at 5 to 10 second intervals. with its own variable time for high voltage polarization,and vary its magnitude, up to 11 kv such as a coil in the water near the plates.
and a separate control , and power source at the plates in resonance. less voltages, between the plates 24 to 36 volt., low amp setting miliamps, at. 20 thousand to 40 thousand hz or is that mhz. . separate power supply, and control for self adjusting resonance of the circuit.. this is what i got out of one such patent that uses a coil as a bias. the gaps at the cells need be in spec. for tubular, and all cells 2 to 4 mm is max gap between plates.:angel:
I cant locate that patent i posted, so if you come across it please pots it here.
