Stan Used Simple Solenoids in 1 ,2 &3 Rail Configuration
these are readily available . Along with ECU the Technology of recycling exhaust gas is
in place on all current combustion vehicles
The EGR Exhaust gate Re cycler solenoids are attached
I have attached erg valves and exhaust coolers which should cover 90% of applications and
can be easy modified. All item off the shelf global basis
the key is knowing , once you know its easy!
Attached are some examples
Easy to find these basic on off fast solenoid in lpg applications or conversion kits
we recommended using a hydrogen injector for cylinder injection but for all other point
the attached example work fine for mixing or timing control applications
http://www.mechanicalengineeringblog.com/tag/dual-fuel-system/
www.securesupplies.biz
