DIY Hacks & How To's: Convert a Battery-Powered Device to AC Power
KevinW_EnhancedLiving
« on November 20th, 2013, 08:00 AM »Last edited on November 20th, 2013, 08:06 AM by KevinW_EnhancedLiving
I was looking to create some of these to help environment....
https://www.youtube.com/watch?v=r4f0Fi_fCyE#t=131
So I am asking for help from some of you that are doing 3D prints to create something like this to sell for a reasonable price.... I want some!
As well as just blank dummie batteries to fill in the spaces
Thank you :)
RE: DIY Hacks & How To's: Convert a Battery-Powered Device to AC Power
« Reply #1, on November 20th, 2013, 05:18 PM »
Quote from KevinW_EnhancedLiving on November 20th, 2013, 08:00 AM
Thank you :)
I'm sorry Kevin, I don't quite understand what it is your wanting. If you do a search on thingiverse you might find the exact item you are looking for then post a link to it, thanks Jeff.:D
http://www.thingiverse.com/
« Reply #2, on November 21st, 2013, 07:48 PM »Last edited on November 21st, 2013, 07:50 PM by KevinW_EnhancedLiving
Quote from Jeff Nading on November 20th, 2013, 05:18 PM
Thank you :)
Hello Jeff!
I want an easy way for people to replace battery powered items, with a voltage regulator and dummie batteries.
http://www.thingiverse.com/thing:118167/#instructions
"Printed in PLA, insert wire with crimp ring in slots on either end, screw in a pan head #8 screw at each end to hold in place and provide contact surface. Negative end will be recessed/flush with battery end. Positive screw will protrude."
I guess this would work perfectly :)
Thanks that was easy
So maybe it would be cool if somebody printed a whole bunch and put them on ebay or something along with something like this video that shows how connect. Or even create kits for less technical people
Kevin
« Reply #3, on November 21st, 2013, 08:02 PM »
Quote from KevinW_EnhancedLiving on November 21st, 2013, 07:48 PM
Thank you :)
Hello Jeff!
Kevin
I think one could utilize some kind of plastic rod the correct diameter, just cut it to the desired length, would be so simple.:D
« Reply #4, on November 21st, 2013, 10:08 PM »
Quote from Jeff Nading on November 21st, 2013, 08:02 PM
Thank you :)
Hello Jeff!
Kevin
True enough Jeff. That would work. I guess this is just an idea for people out their with 3d printer
