Flip Flop Circuit to bypass secondary spark.
Heuristicobfuscation
« on October 29th, 2013, 02:26 PM »
Maybe you guys can help me out with this flip flop circuit....
Video posted bellow..
https://www.youtube.com/watch?v=tTSJZqAPebI&feature=youtu.be
Anyways I can’t seem to get the output to toggle on a consistent rate rater it tends to be random.
My attempt is to find a circuit that will bypass the secondary spark ignition on my small generator so that I can attempt to use it with hho. I was hoping to accomplish that with the steady state of the 7473 IC chip..
Thanks.
xxzeropiontxx
RE: Flip Flop Circuit to bypass secondary spark.
« Reply #1, on October 29th, 2013, 03:53 PM »Last edited on October 29th, 2013, 04:04 PM by xxzeropiontxx
Quote from Heuristicobfuscation on October 29th, 2013, 02:26 PM
Thanks.
I used a 555 timer to set the flip flop for a pulse and ran the out of the 555 to the clock of the flip flop
http://www.falstad.com/circuit/ this might help to a fun toy to have on the desktop
« Reply #2, on October 29th, 2013, 06:21 PM »
Quote from xxzeropiontxx on October 29th, 2013, 03:53 PM
Thanks.
Thanks that confirms what i was thinking... a YouTube reply informed me that i needed a bounceless switch circuit before the flip flop.  Using a 555 timer should help buffer out the noise. I just need to find a circuit layout that will allow a reed switch or hall sensor to activate the 555.
Thanks,
xxzeropiontxx
« Reply #3, on October 30th, 2013, 03:45 PM »
put reed switch inline with the reset on the 555 you will have power to the 555 all the time but it will only send a pulse to the flip flop when the reed is switched to close by the magnet
« Reply #4, on October 30th, 2013, 06:28 PM »
Quote from xxzeropiontxx on October 30th, 2013, 03:45 PM
Sounds good.. i will be looking for a diagram where i can connect the reed on the reset.  Also found  a diagram where it shows a momentary push botton controling the 555, i was thinking of replacing the switch with a reed. check out  image bellow what do you think?
