Newman Motor
RE: Newman Motor
« Reply #1, on October 29th, 2013, 01:15 AM »Last edited on October 29th, 2013, 01:28 AM by Matt Watts
Probably the best tidbit of information to consider in regards to Newman is:
Quote from "Joe Newman"
The facts clearly prove that the magnetic field Z associated with a conductor is not a result of the current or power input into the conductor, but rather is the result of the number of atoms which comprise the turns of the conductor.  This underscores the fact that the magnetic field comes from the atoms of the conductor and not from the current.
What this statement really boils down to is that making a motor with a monstrously large inductor coil can indeed produce the same torque as a conventional motor with much less input power.
Also see the attachment.
RE: Newman Motor
« Reply #2, on October 29th, 2013, 01:16 AM »
So it's a pulse motor then?
Is there a generic schematic for what a Newman motor should be all about?
I guess a relay is not a requirement for such a motor, but it looks cool though :cool:
RE: Newman Motor
« Reply #4, on October 29th, 2013, 06:14 AM »
So it is a pulse motor then.
Does anyone know how many times/revolution the coils should be energised?
Also it would be sweet to see a basic most schematic outlining how "a real Newman motor" should be built, google shows way too many variants of it.
Ravenous Emu
RE: Newman Motor
« Reply #5, on October 29th, 2013, 07:14 AM »
PDF PAGE: 30/338
"His model is based on the assumption that matter is concentrated electromagnetic energy.  He predicts that this energy (E=MC^2) may be released in a controlled way, and his experiments verify the prediction."
 - Mr. Hastings Report
RE: Newman Motor
« Reply #6, on October 29th, 2013, 12:04 PM »Last edited on October 29th, 2013, 12:44 PM by Matt Watts
There's a direct relationship between Newman's gyroscopic particles, Leedskalnin's magnetic currents, Nikola Testa's radiant energy and Tetryonic's equilateral triangle quanta.
It's all starting to fit together and it can't be a coincidence.  There is something fundamental in the behavior here that governs all things; we should be able to manipulate it to our advantage and come up with a functioning energy device.  We can't possibly be more than a step or two away from a working prototype.
RE: Newman Motor
« Reply #7, on October 29th, 2013, 02:32 PM »Last edited on October 29th, 2013, 02:39 PM by Jeff Nading
Quote from Matt Watts on October 29th, 2013, 12:04 PM
Very thought provoking Matt. I think you to be correct. There's got to be a correlation between all of these technologies. :cool::D:P
Quote from Ravenous Emu on October 29th, 2013, 07:14 AM
PDF PAGE: 30/338
Cool Rav good observation. :cool::D:P
RE: Newman Motor
« Reply #8, on October 29th, 2013, 07:21 PM »
Quote from Jeff Nading on October 29th, 2013, 02:32 PM
Something to keep in mind guys, that first video Jeff posted is only a simple pulse motor; it is not a Newman motor.  The easiest way to tell is the commutator.  Newman's design has multiple, FIRE, OPEN, SHORT, connections that are precisely timed to pull-out and re-use the "gyroscopic particles".  See PDF pages 67-77 for details.
Also, to get decent conversion and production efficiencies, you'll need to use high voltage and lots of wire, since current is your enemy and mass is your friend.
RE: Newman Motor
« Reply #9, on October 30th, 2013, 12:52 AM »
Ok, so there is no known schematic for it then.
Too bad.
RE: Newman Motor
« Reply #10, on October 30th, 2013, 10:53 PM »Last edited on October 31st, 2013, 12:45 AM by Matt Watts
Quote from Lynx on October 30th, 2013, 12:52 AM
Too bad.
I'm pretty sure the plans for Big Eureka is out there someplace:
https://www.youtube.com/watch?v=5EL_bLOK8_A
This is over an hour long, but is certainly worth watching:
https://www.youtube.com/watch?v=RMYo1QlvK5g
http://josephnewman.com/
So what do you think?  Is it real?
adys15
RE: Newman Motor
« Reply #11, on October 31st, 2013, 03:58 AM »
Of course is real!Build Bedini ssg and then you know is real,its based on the same principle,Newman uses mechanical switches\comutator to swich the coil generate a backspike and redirect it to the runing bateries closing the loop!
