Manny things around us give out "energy" that no matter what you do do not change which can be converted to electricity. What about thinking of non conventional forms of energy which is original and not commonly known?
I assume some heard about energy from Pee or POOP. Imagine a battery powered motor home which used the toilet to power it.
Here is an odd original one. What about getting energy from your pulse? Wouldn't it be that you do not need more energy to operate it? Obviously not powerful enough to power something directly but only to store energy.
How about about stairs where each step is a 1 inch level to power gears for energy.
Car shocks replaced with gears which every time you hit a speed bump you get energy. Before companies made electric brakes with gears I knew that should have been done which took a while.
Fire places seems inefficient since the heat escapes to rise up. Why not have the fire place below ground level under the home as so that the heat disperses into many chambers to heat the floor then escape outside after being depleted of most of its heat.
Your laptop monitor gives off light at the from but if you take it apart and turn it on even the back of the monitor which is covered gives off light. A solar panel would help it if it was stuck on it without the extra glass on it. Even the laptop heat that it gives out would be good to get power out.
The drain of your sink to get a small turbine every time you use water. What about if you had the water drain into a second toilet tank to be used every time one flushes.
That's just some. I assume others have their own odd ideas.
