i posted this on the wrong thread.
Hi Hi, hey Jeff i remember
I used to have some old drills when i was a kid. big shinny and silver, and i was always amazed how there seems to be sparks ensuing from the motor as i drilled..
I believe its a simple case. the motor on the drill is still tuning the old brush type triggers, and accumulators. it has its own gap. and simply picked up on the added voltage.because the tig is sparking fast too..but is that the case with your drill also?
you had said you got zaped from a printer. it was a 220 volt. but what do you mean? did you plug it into the wrong outlet?
this is gonna work i know it, because Tesla even showed you how to do it. with the transmitter coil, and the reviser coil. Ill add that patent here when i can.
hertz or was it Marconi? referring to the first movie. its telegraphy. i believe thats the case, teals was using brush type motors. same as your RCA cars with the magnetic pickups. or brushes.:blush::heart::blush:
so u can easily power an alternator with wireless energy.the old type were called generators.and are both motor, or generators.
and wow..:cool:
are we really here to do these experiments or are we sheep being lead to the wolves?
i can tell you this if it is as Maxwell had said, and we are dragged by the chariot. we are gonna have problems. jan 1 2014 starts the follow up. after 4 years observation.
well,sorry about that let me get. back to Tesla. if indeed he had a build up of pressure ensuing from a sphere of high potential. that would be what was in oscillation through the ground.
how far can we take this? in my understanding that pressure must have been against the ground. and it likes to carry these wave. transverse i believe they are called? refer to movie one.
now i take a Tesla coil i hang on a thread a needle or a pin.
i add another sphere of large radius. I confirm there is equal potential charge on each sphere. i see that pin swing under electric tensions. its magnetic component travels through dielectric material better then ferrite.
so you have that. how far shall we go for theory? simple experiments should follow..
ehhe cheers.
:Dhere are all of the patents.
i link one for the transition of electrical disturbance. sounds like a lightning storm to me. refer to star trek new movie for the impossibility of a lightning storm in space. i simply disagree. it can occur under certain conditions. But Tesla has a lightning detector on the other end? i think it is...
he stepped it down and used it how? we will see...
http://www.teslauniverse.com/nikola-tesla-patents-381,970-electrical-distribution?PHPSESSID=i364trg0ea6dlq7im8p5n1d4u3;http://www.teslauniverse.com/nikola-tesla-patents-382,282-electric-converting-distributing?PHPSESSID=i364trg0ea6dlq7im8p5n1d4u3;lets find the similarity in these patented, and compare to Tesla coil.. tasked.. tss tsss tiss:P:P:P study time. Tesla refer to these induction motors in patents...notably in those having serial numbers 252,132 and 256,561
tesla "The generator in this system will be adapted to the converter in the manner illustrated. For example, in the present case I employ a pair of ordinary permanent or electromagnets, E E, between which is mounted a cylindrical armature on a shaft, F, and wound with two coils, G G'. The terminals of these coils are connected, respectively, to four insulated contact or collecting-rings, H H H' H', and the four line-circuit wires L connect the brushes K bearing on these rings to the converter in the order shown. Noting the results of this combination, it will be observed that at a given point of time the coil G is in its neutral position and is generating little or no current, while the other coil, G', is in a position where it exerts its maximum effect Assuming coil G to be connected in circuit with coils B B of the converter, and coil G' with coils B' B', it is evident that the poles of the ring A will be determined by coils B' B' alone; but as the armature of the generator revolves, coil G develops more current and coil G' less until G reaches its maximum and G' its neutral position. The obvious result will be to shift the poles of the ring A through one quarter of its periphery. The movement of the coils through the next quarter of a turn, during which coil G' enters a field of opposite polarity and generates a current of opposite direction and increasing strength, while coil G is passing from its maximum to its neutral position, generates a current of decreasing strength and same direction as before, and causes a further shifting of the poles through the second quarter of the ring"
I note the use of collecting rings.and iron wire yea.. is this reference to a brush type motor? find out here>>>.notably in those having serial numbers 252,132 and 256,561
