Hello everyone,
Thought this to be of some importance
http://www.aluminumflux.com/
Degassing Fluxes
Hydrogen, found in the foundry primarily due to the decomposition of water vapor, is very soluble in liquid aluminum alloys, but much less so in the solid phase. When aluminum solidifies, the excess dissolved hydrogen comes out of solution and forms bubbles, from pinhole size to much larger sizes. Metal which has not been degassed before casting is vulnerable to this type of defect. Degassing fluxes remove hydrogen, and also oxides and other impurities.
I know this to be true as I have cast aluminum for 35 years, made many parts and built many things in aluminum.
Found it to be very odd at first, that the hydrogen created within the heated liquid state of aluminum would not burn or explode, but then realized there was no oxygen, needs three things to burn heat, fuel and oxygen.
Magnesium creates hydrogen as well and why magnesium fires burn very hot, blinding white hot.
Hydrogen is a very interesting gas and the more we know about it the better our chances of discovering it's secrets to use it as fuel.:D
Degassing Fluxes
