Carbon Dioxide-CO2 is a natural refrigerant which turns cold if moving a higher to a lower pressure. This being the same for all refrigerants.
This process occurs when a block of Dry-Ice is put into the DaS turbine boiler.
The Dry-Ice at -40*C flashes of into gas and rises to 10,000 bar pressure at +100*C. Pressures of that force require construction using Stainless Steel. Lesser pressures need lesser less grade material. The working pressure is that found between cold point and hot point. The process works by having fluid block the CO2 gas from getting to the expansion chamber. This causes the CO2 to built up enough pressure to force the fluid out of the way. The fluid pushed out of the way drives a hydro turbine. When the CO2 has pushed enough water out of the way it trips an escape valve allowing the CO2 to travel to the expansion chamber. In this happening the cold gas held in the expansion chamber exchanges place with the CO2 in the boiler. During this process the fluid is draining back to again block the CO2 movement. Once started it will never stop due to the fridge physics of always returning colder gas to the boiler no matter what the boiler heat may be.
Construction including the turbine requires pipe, one way valves and a floating ball.
Posted in Open Technology free to copy.
