So where are we at?
Could we agree that parts of the recipe to the secret sauce is using plates or tubes submerged in water which we apply some electric voltage of sort to in order to get a high flow of explosive gas out of it?
To be added to that then either some form of catalyst or curing/preparing/coating/electropolishing the tubes or plates to get some dielectric or semiconductor layer on them to help boost performance.
How would one go about finding the correct resonance frequency then, if it exists at all?
Would you look for a sudden increase of gas production or subjecting the gases to a soap bubbles test, setting the bubbles on fire and listen to, or measure, changes in loudness of the explosions?
Maybe the only way here would be to actually feed the gases to a motor and look for changes in RPM's?
How would you define the prerequisites for a successful test that which definitely says that you have found proof of concept for a true Meyer WFC?
Brainstorm away Ladies and Gentlemen.
