Just found this photo of Stan's Dune Buggy engine, it's all labeled
[attachment=4234]
[attachment=4234]
Hi all,
I have spent some time looking at video's with Stan's dune buggy actually running or at least the engine running. Now I must say that I have no sound on this computer, so perhaps I overlooked one, but so far I have only been able to find ONE single video wherein the buggy is actually running:
https://www.youtube.com/watch?v=GFIlXaABU54
In this 1992 video, I can't see the engine running, for example:
https://www.youtube.com/watch?v=tXTzBuIrVj0
This raises a number of questions, but the most important one is: Why can't I find any footage showing a running dune buggy except this single one?
I also took a look at some of his patents. The resonant cavity one dates from 1982 (priority date, date of first filing). The pictures in the dealership manual are all dated between 1981 and 1983:
http://www.tuks.nl/pdf/Patents/Meyer/Stan%20Meyer%20Dealership%20Sales%20Manual%201986%20OCR%20CONVERTED.pdf
There is a "hydrogen gas injector" patent with a priority date of 1982, but that one is not the all-in-one injector intended to replace a spark plug, but appears to be a system to inject the gas into the air intake system of the engine:
http://www.tuks.nl/pdf/Patents/Meyer/Hydrogen%20gas%20injector%20system%20for%20internal%20combustion%20engine%20-%20EP0086439A1.pdf
That what we know as the injector, though, has a priority date of 1991:
http://www.tuks.nl/pdf/Patents/Meyer/Water%20Fuel%20Injection%20System%20-%20WO9222679A1.pdf
So, it appears to me we are looking at a working dune buggy somewhere around 1980 - 1985, while I can find no evidence whatsoever that the car ever ran after that time frame.
This begs the question: did the injector system ever work?
If it did, why can we find videos of Meyer explaining and showing the car, but not a single one wherein the car is actually running? Why would he not show the car running, unless it was uncapable of doing so?
Take this video, for example, a documentary aired by the BBC:
https://www.youtube.com/watch?v=vE6AkSE2JCk
This has been aired in 1994 (http://www.hho4free.com/stan_myers.htm ).
I mean, come on! You get the BBC visiting you for a documentary, THE chance of a lifetime, and all you can do is push your car out of your garage? Yes, the car is shown running in there, BUT that is OLD footage from the Ohio TV program, which probably aired somewhere around 1981 - 1985.
So, how come Stan had a running car somewhere around 1981 - 1985 and never ever got it running on water again? Cause, that's what you reasonably have to conclude, given the footage we got.
Of course, one can also conclude that the whole thing was a scam, but I don't believe that, given the replications of a/o Ravi, Lawton and Cramton. And of course, I have a decent theory which explains exactly why these replications were successful:
http://open-source-energy.org/?tid=1168
My basic conclusion is that the system won't work as specified, unless he would have used electropolished stainless:
http://open-source-energy.org/?tid=1372
I also received some private messages at the energetic forum:Googling for that name, I find another dated photograph:Quote the stainless tubes were of differing gauges and likely purchased or obtained as scrap. (See magnifiied images and photogrammetry at ionizationx)
A common place to get scrap metal at the time was the Joyce Ave Scrap Co. located in Columbus
In fact look at p 40 of the IITER report and he used a company called Materials Joining Company Col-x locacted at 901 East Hudson which is just a couple miles from the scrap yard the characteristics of the samples stan provided are listed
According to Charlie Hughes when Stan was running the tractor at the farm, it had about 50 exciter tubes (listen to phone interview)
http://www.dispatch.com/content/stories/local/2007/07/08/hydroman.ART_ART_07-08-07_A1_4V77MOK.htmlI can't seem to find the interview mentioned. Perhaps one of you has it?Quote Stanley Meyer during a test of his dune buggy, about 1980. This screen shot was taken from a DVD sent to The Dispatch by his twin brother, Stephen Meyer.
When we add all this together, I think we can reasonably conclude that Stan got his car running ONLY during the early 80's and that it is likely that he used scrap components. So, it is entirely possible and even likely that he just happened to get his hands on a set of scrap electropolished stainless tubes, whatever the source of these might have been.
Why, oh why, is there a chemical analysis of the stainless he used dated december 22, 1982?
http://www.tuks.nl/pdf/Patents/Meyer/WFCreport.pdf
(page 46)
Why did he also let them test his water sources?
Because he got a set of working tubes, but was unable to repeat his results with other tubes, that's why! And he had no idea what the heck was so special about these working tubes.
But we know almost certain why. This special set he had analysed for it's chemical composition happened to have been electropolished and thus contained a thicker layer of Cr2O3 as usual. A tiny little detail which would not show up with chemical analysis....
Therefore, I am tempted to conclude that he only got ONE single set of tubes working due to a "lucky shot" and that the injector system never actually worked. And I actually think it will never work either, because the surface area with the dielectric which does all the magic is much, much smaller than in an electrolyser system.
Pollack experimented with water when subjected to hydrophobic materials. What happens then is that the water comes in a state which is believed to be somewhat in between liquid water anc ice.
What it does, is form a honeycomb crystal, very similar to the crystal structure it forms when freezing. However, in frozen state, the crystal is rigid because layers of these crystals are bound to one another by hydrogen atoms. These bridges between the layers make that these cannot move with respect to one another and thus the structure as a whole gets rigid.
In the state which Pollack call s "EZ", for exclusion zone, microspheres and other contaminations are pushed away into the bulk water, which suggests a connection to ice crystals. They observed the thickness of this EZ layer to grow when infrared light is radiated on to the test material and they found a specific wavelength which works best:
Found the logo at least, but not much else.
http://www.mail-archive.com/interact%40listserv.capital-master.com/msg00047.html
Interesting his little fuel making box has two wires with no battery. I would have to think that box took an absolute boatload of energy to make. The energy had to come from somewhere didn't it?
Anyway, good find EZ. Definitely something to think about, hoax or not.
There's a copy of the website at archive.org:
http://web.archive.org/web/20090323214201/http://www.biosmeanslife.com/home.html
Cool thanks lamare.Quote from lamare on October 19th, 2013, 10:38 AM There's a copy of the website at archive.org:
I have to wonder though, if there really is such a thing as "water that burns", does that water freeze? If it does, at what temperature? If it does freeze, after it melts, does it still burn?
