When I see this stuff...
RE: When I see this stuff...
« Reply #25, on September 20th, 2013, 11:52 PM »
Quote from freethisone on September 20th, 2013, 10:25 PM
https://www.youtube.com/watch?v=yDtXR_1Ubs8
this is the first movie i watched of yours.  i like the circuit. a self oscillator is perfectly fine.your bedini oscillator is amazing i would buy if it was available.. or you could try a self oscillation  static trigger like i have done in a tesla coil experiment.
but if you want to try an experiment add a large metal nut to the end of your wire spool. is that like an antenna? Tesla may consider this as adding a capacitor in this place causing a strong current to pass. it counteract the self inductance.
in any case you may find a very small metal nut placed at the end of that spool could increase output.. acting in series as a capacitor... Tesla specified metal plate..
what do u think?  i was also thinking along the lines of battery's...
how about duplicating  a Tesla:D cast iron tub battery. well over 120 volts. high salt concentration was used...
you could turn the dead sea into a gigantic battery...or even natural  salt flats.... :heart::heart:
That's ol' Aaron Murakami doing the video.  His Ignition Secrets videos were pretty good stuff.  I learned how to make a booster cap system that makes a powerful, rapid plasma discharge across an ordinary spark plug.  You can get in touch with Aaron at: info@emediapress.com
« Reply #27, on September 24th, 2013, 07:08 PM »
Quote from FaradayEZ on September 24th, 2013, 05:22 PM
When i see this stuff, i want him to push the thing over the floor to see that it hasn't got a wire via the ground attached.
http://peswiki.com/index.php/Directory:ValyEnergiStar_Self-Looped_Motor-Generator_System#Energy_Free_Puncto_Zero
Yep, I hear you.  Sterling was ready to put it in the number one slot until Russ discovered the wood running all the way to the bench for no apparent reason other than concealment.
It's a bummer folks go out of their way to pull these kind of stunts.
Mechanic
« Reply #28, on October 6th, 2013, 03:39 PM »
Sorry. Letter betwee m & o is  ot worki g. A electret has a coti g ge arati g its ow  voltage  ot true ?....
« Reply #29, on October 7th, 2013, 06:34 AM »
Quote from Matt Watts on September 24th, 2013, 07:08 PM
Lets tease the fellow and buy a one watt engine from him..lol
haiqu
Re: When I see this stuff...
« Reply #30, on March 9th, 2014, 10:00 PM »
Quote from Matt Watts on September 5th, 2013, 10:57 AM
You know, I was thinking about this last night.  What would be the best alternative to fully dumping an invention into the public domain?  ???
Answer:  Making the invention appear as though it's a hoax and tossing over a few business transactions to get people claiming you are a scammer.  Do that and no one, not even the bad guys would touch you with a ten foot poll.  I have to wonder how many times this technique has been used.  For some it would sure beat having to look over your shoulder constantly for the rest of your life.
On the other hand, just because you're paranoid it doesn't mean they won't get you in the end.
Lynx is right, until you have it running on your own bench or in your own car, it's nothing more than a pipe dream.  I still think it's cool to look at though and wonder if it's really possible.
I think we see eye to eye on that.
