I do not seem much info online just sloppy methods. Now if you wind a coil tight one direction, let's say left to right 20 times, then do you have to make the same turns from right to left 20 times? Do you go right to left 1 or at little as possible to do another 20 turn from left to right? Or it does not matter on the first or multiple layers which random pattern it goes? Obviously all going in the same direction clock wise or example.
Would it matter if it is short of long or it its for an electromagnetic induction or magnetism an object? Since it almost seems like if it was an electromagnetic induction the one side will be charged first and the charge would collide with each other to cancer it out to a degree if it is left to right and right to left in an even number. If it does not matter how come it would not negate it?
So is there a proper or improper way to wind a coil? If you need me to explain better ask.
