I'm sure some one has already thought of this... However...
Why not modify a CNC milling machine into a 3D printer?
The main modification would be to make an interchangeable print head.
(I.E. I want to be able to use it as a milling machine too.)
What are your thoughts?
Easy? Hard? Simple? Complicated?
Where to place the filament? ... ...
I was thinking about locating it on the Print Head itself. So, it moves with the head and won't interfere with the print.
Or...
Construct some sort of box that encases the whole work. Place the filament on the top of the box. Then you feed it through an opening in the top. That way the filament is still out of the way of the print.
http://grabcad.com/library/cnc-3-axis
http://grabcad.com/library/3-axis-cnc-model--1
http://grabcad.com/library/cnc-router-3-axis-1
Or...
