This is from the site "How stuff works"
"During the tests, engineers from Allis-Chalmers grew concerned about both the mechanical efficiency of the turbines, as well as their ability to endure prolonged use. They found that the disks had distorted to a great extent and concluded that the turbine would have eventually failed."
"But Rice, an expert in fluid dynamics and the Tesla turbine, conducted a literature review of research as late as the 1990s and found that no modern version of Tesla's invention exceeded 30 to 40 percent efficiency.
This, more than anything, prevented the Tesla turbine from becoming more widely used."
http://auto.howstuffworks.com/tesla-turbine4.htm
Do others here agree that it is only 30-40% efficient?
If some say so then I say the design is not as efficient in what material or how its made to perform well. Since water going through a tube in your home hits the inner walls of the pipe, but the same with a Tesla turbine to hit the walls of the smooth disk and the pressure gives it its movement. I see people say they made Tesla turbine but they seem to go against the notion of having no resistance when they put holes in the disk for grip and traction, or blades... so it seems.
