Here's a little something to take a peek at:
https://www.youtube.com/watch?v=nKJuuYwyyUg
Take the producer of this video with caution as we have had a few go-arounds with him. What I want you to notice is the flow-rate in the bubbler. It appears to be around 20 LpM (he says 14), so I'm guessing that generator motor is less than 300cc displacement. Notice also when he plugs in the load, the load is only a little 20 watt fan motor. So to get 20 watts out of usable power, he is probably dumping in over 2000 watts of electrical power to energize his cell.
I base the comparisons on my setup--8 LpM, 305cc motor, which would barely kick over. At 8 LpM the bubbler was going absolutely nuts and I was pulling 13 amps at 120v from the wall to get it.
BTW, the numbers Gary Hendershot came up with are: 1 LpM for every 10cc of engine displacement; that's to have an engine that can actually do more than just spin itself with no load. So for my 305cc engine, I'd need 30 LpM. And 30 LpM, would take at least three of my big 60 plate cells running wide open, each drawing 15 amps at 120v. So you can see, it's a zero sum game here.
All-in-all a cute video, but if you pay attention to the details you'll see why doing this is pretty much a dead end unless you just want to make cute videos.
Now if someone comes up with a good way to take a 60 plate cell like mine, feed it 10 amps at 120v and produce 30 LpM of HHO via cavitation or some other means, then we're back in business.
