hello there,
from all i have read magnet motors should be considered a dead end because no functioning device was ever produced in the last 100 years but i have this stupid idea stuck in my head and i want to get rid of it and maybe some of you guys can follow my thoughts.
okay now let me explain what i think is going to happen.
everyone knows we have a attraction force between two different permanent magnet poles and the closer they get the stronger the attraction becomes but we also have a change of magnetic flux while the magnets align each other so why dont we capitalize on that and mount a coil around one of the magnets (in my example the coil is wrapped around the stator magnet). What this should do is induce a current into the stator coil and we know from transformers that the induced dircetion of the current will produce a magnetic flux which direction will counter the flux of the permanent magnets. So in my head the magnetic field of the stator magnet and the magnetic field of the induced coil current will cancel each other out so the attraction force between the stator and the rotor magnet will not increase but decrease! in the end this should allow the rotor magnet to pass the stator magnet without any attraction and with enough momentum the disk must spin for another half turn. then we can release the energy stored in the stator coil and the attraction force of the magnets will appear again, restarting the process.
let me know what you guys think of this idea
