free energy claim
free energy claim
« on June 29th, 2013, 04:37 AM »
i met a guy, he told me how he did it.
the car ran 2 years.
golf cart motor? gen 8500?
he took 6 mini turbines, modified the chips for voltage. and had power to spare.
18 volts.
initial via chip or solder, to modifies turbine voltage output..
it worked,o charge an extra battery. to dump some of the excess free charge.
:D
RE: free energy claim
« Reply #1, on June 29th, 2013, 05:55 AM »
Quote from freethisone on June 29th, 2013, 04:37 AM
18 volts.
Please excuse me for not understanding here.
Was it a golf car he drove around for absoutely no cost for 2 whole years?
How were the 6 mini turbines assembled?
I can understand that the turbines helped charging the golf car batteries and then some, but just how were they used exactly?
Again, I'm sorry for my questions, but I honestly just don't get it.
Thanks.
« Reply #2, on July 2nd, 2013, 03:43 AM »Last edited on July 2nd, 2013, 03:45 AM by freethisone
Quote from Lynx on June 29th, 2013, 05:55 AM
18 volts.
Thanks.
he said it was bigger then a golf cart, but tied a rope to the wheel and let it go in circles for 2 years.
the turbines were assembled behind the grill. they are the very small mini type.
they can be modified for output.
he used 6 of them.
1 extra battery in the back 12 volt. to dump excess charge.
the point he made is you cant patent this. but it will work..
« Reply #3, on July 2nd, 2013, 04:04 AM »
Quote from freethisone on July 2nd, 2013, 03:43 AM
golf cart motor? gen 8500?.............
Please excuse me............
Thanks.
he used 6 of them.
Ok, thanks.
So he had the car itself running around in a circle with 6 turbines at the front behind the grill which in turn provided juice to charge the batteries so the car could keep on going and going around in that one and the same circle for 2 whole years, am I correct so far........?
Awesome in that case!
« Reply #4, on July 2nd, 2013, 07:56 AM »Last edited on July 2nd, 2013, 08:01 AM by freethisone
https://www.youtube.com/watch?feature=player_embedded&v=mFYkW5mvjSo
Quote from Lynx on July 2nd, 2013, 04:04 AM
Thanks.
he used 6 of them.
Ok, thanks.
yes that is what he did.  here is a link to wind turbine projects .  http://store.kidwind.org/wind-energy-kits/complete-kits/mini-wind-turbine
http://www.gotwind.org/diy/12-inch-mini-turbine.htm
« Reply #5, on July 7th, 2013, 11:07 AM »Last edited on July 7th, 2013, 11:14 AM by freethisone
Quote from freethisone on July 2nd, 2013, 07:56 AM
Thanks.
he used 6 of them.
Ok, thanks.
https://www.youtube.com/watch?v=GPJao1xLe7w
http://laserhacker.com/
this is the solution to the mini turbine. together theses boost  packs and mini turbines, or car alternators will give you all the free energy needed to run a electric car for thousands of miles.
and is a perfect use for your ssg russ.
« Reply #6, on July 7th, 2013, 05:22 PM »Last edited on July 7th, 2013, 05:28 PM by freethisone
:angel::to test truth of concept. assemble 6 mini turbine windmills on a merry go round.
feed the merry go round spin. and that will produce wind for the turbines to spin. you will measure what you feed the motor to spin the merry go round, hint ssg. once you have a base line. efficiency will be fine tuned. and we will know once and for all how much energy is free.
Russ you can add the mini turbines to a spinning wheel. and obtain rotation at the blades for charging a boost pack.:P
« Reply #7, on August 6th, 2013, 03:06 AM »Last edited on August 6th, 2013, 03:26 AM by freethisone
Quote from freethisone on July 7th, 2013, 05:22 PM
you know i give freely my invention to anyone who wishes to develop a test set up.
any way idc, so i would invent, conceived the concept.
Shrink  the wind turbine to the size of a pinwheel, and simply use 100 to catch the wind from a sailing ship of free energy.
as its not really over unity, but the vacuum point energy is vast like the sea. just like the wind the more sails to catch the wind the more you get for free.
https://www.youtube.com/watch?v=qwF5n67yjx8:D
in this case i deal with the equal potential of the conductor as my vacuum energy source, but in the same manner of adding more capacitors to my setup, a wind turbine  includes more sails in the shape and size of a pinwheel..
i have also advanced the shape and size, also partial function of  solar panels to use the photon energy more then just one time before it is reflected back into space. It also eliminates the need for a solar tracking system. hint.. i would expect it to be 400% more efficient also. therefore the cost of one panel  can be minimized, and output maximized.
any one who wishes to develop my panel contact me.
« Reply #8, on August 9th, 2013, 06:17 PM »Last edited on August 9th, 2013, 06:20 PM by freethisone
Quote from freethisone on August 6th, 2013, 03:06 AM
over the last few days i conceived away to test the theory. in other words. if you own panels already you can now buy these adapters, and increase output of the existing panel.
a small test panel is needed. 15 watt..
the object would be to obtain 60 watts. could it really be done? i think it can.
