How can one get more out of a fixed number?
In your device you put in 10 volts and you minus 2 for friction, minus 2 for other inefficiencies, you end up with 6 volts output which is only 60% efficient which is pretty good compared to a car that is 30%. Even if you have no friction and your device loses .01 in other losses then your device will output 9.99 still not 100% which you break even. Even if you put what power it gives out back to the device to wind it down slower to be .000001 more efficient it will still not be over 100%
So what math do people think that starting off with X amount of power will give you X+1?
Let’s say hypothetically that you did make a device that is 99% efficient then what would be the math or device to make it 101%?
It’s like trying to get more 2 times the room from inside a box while the outside is the same. You can make the calls thinner in the cube to make it 99% efficient but not 101% or 200% efficient. Where does the extra space come from? Or even a full box with water bottles to be able to take 2 times the amount of water. It’s as if you can find a way to get more energy from X amount then you made perpetual motion, and if you find a way to get more room from x amount then you made a worm hole. And the water has to be shrunk down in volume by atomic compression let’s say to fit more.
Unless we take a cheap approach to say a box will join with another box to double its space, the water you free it without the crystals forming, and an energy device has an outside source.
So the only solution in a basic math problem would be 10 input, -4 friction/inefficiency, +5 outside free source like small $5 solar panel, or wind or whatever, to be 11 volts.
And use that 11 output to redirect it back into the device to to be -4 friction +5 outside course and it will be 12 output, and so on to the point the coils can handle the voltage, and up to that point it is used in a bigger device that take take 100 volts, and so on.
Kind of like sales how you buy a product (orange), sell it, use the money to buy more, to sell, and so on. It seems to only be a one step back two steps forward. Obviously a faster way it to do 10x2=20 but no one can multiply the Oranges out of this air.
Anyone have any other suggestions on how to mathematically attain X+1 to infinity and explain how it might be done?
