That's really cool Nate and really quiet too, nice build.Quote from firepinto on April 29th, 2012, 03:53 PM New Y axis drive. :)
www.youtube.com/watch?v=uZ6OD7tsTWM&
I'll post up the files for it soon.:cool:
lol Well so much for getting my Kapton tape this week. UPS required a signiture, and after the 3rd attempt they returned it to sender. I better get a refund out of this. lol I think it's bs that they dont inform you that they are shipping with a signiture requirement. Gotta love being a nomad!
Sorry Nate, I did not remember that they required a signature.Quote from firepinto on June 8th, 2012, 04:06 PM lol Well so much for getting my Kapton tape this week. UPS required a signiture, and after the 3rd attempt they returned it to sender. I better get a refund out of this. lol I think it's bs that they dont inform you that they are shipping with a signiture requirement. Gotta love being a nomad!
Started building my new power supply for the Dell NPS-700AB A. Printed 3D files can be found here. I'm still missing some parts and other parts need an upgrade in amperage rating. Enjoy the pics!
Hope to have more soon!
I will be getting back into 3D printing shortly. It has been a while since I've touched the MakerGear Prusa. :)
I really needed a glass bed so I recently got a borosilicate glass bed from Lulzbot. Will need to install.
http://www.lulzbot.com/?q=products/borosilicate-glass-bed-300mm-x300mm
So first my extruder gear snaps off a tooth, now the arduino disconnected half way through a print. :dodgy: So I jimmy the USB cable and reconnect, all looks good again. So I tried the Recover button on pronterface, which i tried once before with bad results. Well I forgot to turn on the heat again so it started with out extruding. So, pause let warm up. Try Recover again.. first layer seemed to go well. Next layer........ Z axis moved down! $%#&^$!!:@:dodgy: If you dont have a spring loaded bed I would never push that button! LOL my luck. I've been trying to print these two parts for 3 days. Lets hope this one works!
Yes, I know the feeling, I've had the hotend crash into the heated bed more than once. I wonder if Russ has thought about that for the Rostock printer.Quote from firepinto on January 4th, 2013, 06:50 PM So first my extruder gear snaps off a tooth, now the arduino disconnected half way through a print. :dodgy: So I jimmy the USB cable and reconnect, all looks good again. So I tried the Recover button on pronterface, which i tried once before with bad results. Well I forgot to turn on the heat again so it started with out extruding. So, pause let warm up. Try Recover again.. first layer seemed to go well. Next layer........ Z axis moved down! $%#&^$!!:@:dodgy: If you dont have a spring loaded bed I would never push that button! LOL my luck. I've been trying to print these two parts for 3 days. Lets hope this one works!
Interesting Nate, but I am a little confused. When I first got my CNC router I read a bunch of stuff about limit switches--oh how they were so vital, but you can run your machine without them. Being a little impatient, I decided to run my machine without them. I've never looked back. With a decent CAM program, you set your start position, check your boundaries and run the thing. There's no need for limit switches. As long as you are certain your X, Y and Z run smooth and you don't stress the steppers by trying to cut too fast or too deep, it works like a charm. I've done runs of over ten hours and when I send the machine home, it is exactly right where I started from.
So am I to assume these RepRap printers don't have that kind of accuracy or does the software try to move the stepper motors in such a way they lose their positioning? Just curious.
Hey Jeff,
Check out this Mendel modification:
https://www.youtube.com/watch?v=vVHvbCfxZdU
http://www.thingiverse.com/thing:8852
I think we should take this idea out fishing, what ya think? ;) I've thought about this before, using a block and tackle setup but didn't think it would move both directions easy. I'll try to get to this soon. :cool:
Watching that video, it doesn't move very fast. Is that normal for RepRap printer? My Probotix CNC moves that fast and it uses direct drive screw threads instead of belts and still has 2000 steps per inch.
The operation of the parts moving look to be very precise. This design would increase torque so you could increase the size of the printer and move heaver loads with the same electronics and steppers we used, cool design. :cool::cool::D It would be more costly to build, more printed parts and longer belts, but with a larger print area it would be worth it. :cool:Quote from firepinto on September 4th, 2013, 07:15 AM Hey Jeff,
