Help!!! Spice Netlist
cory991
« on May 27th, 2013, 08:44 PM »
Im trying to test a circuit made from Diptrace in LTspice and im having a problem with one of the models. Listed below is the error log and subroutine
Circuit: *** Component Net List Start ***
Error on line 53 : opmodel1.cir - opamp model single-pole
    Unable to find definition of model ""
O: lossy line series resistance not given, assumed zero
O: using linear interpolation because trytocompact option specified
O: lossy line series inductance not given, assumed zero
O: lossy line parallel capacitance not given, assumed zero
Fatal Error: O: At least two of R,L,G,C must be specified and nonzero
OPMODEL1.CIR - OPAMP MODEL SINGLE-POLE
VS   1   0   AC   1  PWL(0US 0V  0.01US 1V)
XOP   1 0   3   OPAMP1
RL   3   0   1K
* OPAMP MACRO MODEL, SINGLE-POLE
* connections:      non-inverting input
*                   |   inverting input
*                   |   |   output
.SUBCKT OPAMP1       1   2   6
* INPUT IMPEDANCE
RIN   1   2   10MEG
* DC GAIN=100K AND POLE1=100HZ
* UNITY GAIN = DCGAIN X POLE1 = 10MHZ
EGAIN   3 0   1 2   100K
RP1   3   4   1K
CP1   4   0   1.5915UF
* OUTPUT BUFFER AND RESISTANCE
EBUFFER   5 0   4 0   1
ROUT   5   6   10
.ENDS
* ANALYSIS
.AC    DEC    5 1 100MEG
*.TRAN    0.05US  2US
.PLOT   AC    VM(3)
.PROBE
.END
Theres alot of this i dont understand so any help would be greatly appreciated.
RE: Help!!! Spice Netlist
« Reply #1, on May 28th, 2013, 04:56 AM »
Quote from cory991 on May 27th, 2013, 08:44 PM
XOP   1 0   3   OPAMP1
RL   3   0   1K
*                   |   inverting input
*                   |   |   output
* INPUT IMPEDANCE
RIN   1   2   10MEG
EGAIN   3 0   1 2   100K
RP1   3   4   1K
CP1   4   0   1.5915UF
EBUFFER   5 0   4 0   1
ROUT   5   6   10
.ENDS
* ANALYSIS
.AC    DEC    5 1 100MEG
*.TRAN    0.05US  2US
.PLOT   AC    VM(3)
.PROBE
.END
Great to see you working with LTSpice. there is a competent usegroup at http://tech.groups.yahoo.com/group/LTspice/
they are competent and responsive :-)
I´m not that much in the details of LTSpice that I can support you by myself. I´m not using Netlists that much.
Cool to see you here as a member!
cory991
« Reply #2, on May 28th, 2013, 10:53 AM »
Hey thanks alot for the info. Ill be sure to check them out.
Cory
