Hi
I could be wrong but so I am asking to understand. When you put water into a bucket with a hole in the end you get 100% efficiently for what water goes in water goes out. But when you deal with devices with coils its not eh case, so the problem is impossible and to give up? Meaning the coil should be looked at again since that the the main weak point it seems for some to take a second looks from time to time with the new discoveries.
When you see the small circles in the diagram and the arrows going one way while the other is rubbing on it the other way it seems like friction in the electromagnetic sense, which friction always reduces the power.
Now if you use other physics for rubber gears it won't it would be a lot of friction, if you use water it wont work as well as smoothly. Friction always is bad no matter if its air friction, physical friction, or electromagnetic friction. Maybe some might say its 1 step back and 2 steps forward. Now if some say it gets together with the bigger loop that still won't take away the fact that their is a small gap in between and if it just makes the big gap you might as well use a blat piece of metal that can cover the entire pipe.
Some can say my question is wrong so how does not produce some loss?
Some might feel the Muller coil is the way to help with the distance away form the core but it still has friction.
Even the tesla bifilar has a good idea to give a boost but still friction.
A good step in the direction might be the "star challis coil" but that seems better but has friction when you wind a lot of coil.
Weather right or wrong, I hope some people take a second thought if possible.
Thanks
Thanks
