Everyone,
I notice a handful of people (maybe a dozen) appear to be active/regulars. I know this site is more than just meyers research.
After expending (like many of you) countless dollars and countless hours, I am wondering how much of what we are doing is spinning the same wheel?
There is a TON of information spread throughout various threads. Some absolute garbage and links to very questionable pieces of information, and other true gems...
What I am looking for is for people to chime in on THEIR progress to date, and where their successes have been, and what PIECE of "Black Magic" is needed for them to create the "Meyers Effect"
I am also coining that phrase to mean the basic disassociation of H2 from 0 without current, as exmemplified in "It runs on water". His simplest device. Regardless of the device used.
My goal is to ascertain:
- Where we are at (as a group and individually)
- What skills/interests are available to the group (for leveraging, if possible)
- What technologies worked, and which ones should be avoided (and why)
- What we can do so that everyone can actually create The "Meyers Effect" on their own
After that, everything else becomes easy...
Let me start off:
- I have an 8 Tube Set (4 active, 1 of which is insulated with a clear coat)
- I have a Function Generator, Rigol Scope, Variac, 2 power supplies, and a custom circuit pushing the power with Gating via the function generator
- My background is Software Development, and Skunk Works (creating highly successful projects with very few people, by focusing the right energies in the right direction)
- My degree is Comp Sci, with a minor in Math
- I am learning the electronics, etc. [One of the hardest parts for me]
- I try building things in components that I can re-assemble in different orders for testing (my circuit board is mostly stand-off mounted devices/wires so I can plop it in my box and replace it/components easier.
I have seen/generated the VERY BASICS of the Meyers Effect with my INSULATED Tubes and lower voltage. You can literally see a spontaneous Voltage Drop with a release of HHO, and then the charging of the Capacitor from the Inductor (even if pulsing is turned off).
I am *Desperate* to get High Voltage going into the cell (I just discovered the Diode I was using only handles a back voltage of about 280V and that was the limit of my circuit).
I do NOT have a transformer IN PLACE. I am going straight into Inductors/WFC. So, there is a bit of a lack of isolation, and the first problem for the Diode.
I am also looking for the PROOF/NUMBERS of current and Voltage Meyers was actually consuming. There are numerous threads out there that he overstated his results. One issue with his BASIC design was that his ammeter was placed AFTER the pulsing Diode. This is great if you are measuring Amps in the circuit. It is HORRIBLE if you are measuring the power being pushed into the system, especially if coming from a Variac, where you could be drawing 5-10 Amps at 100V (I get IMPRESSIVE Output at about 50V from the variac (through a bridge rectifier). Even scary output).
Finally, I would like to get things organized a bit, so that we are constantly boiling things down to the basic ideas/circuits/patterns that work. And some standards so we can tell if something goes from 80% efficient to 85% or 70%... (gpssonar started a great thread on calculating the Lx/Cx Impedance matching).
Anyways, I would like to ask that EVERYONE ELSE SOUND OFF and chime in with where you are at, what you have, etc. in the hopes that we an all stand on the shoulders of those who came before us and get there faster!
Kirk Out!
Let me start off:
Kirk Out!
