Hi ya Russ, do these pictures give you any ideas of a new style EPG design, it does me, of course without the cooling fins. I am helping restore an old 54 Buick Special, I saw this heater core and ideas started popping up in my head. What would happen if we were to install the pulse coils in the same circle as the copper tubing, three sets of tubes soldered to two manifolds and one set of pulse coils in between the manifolds. It would pulse all three tubes and possibly create three phase in one EPG unit. This is what I want to try, others might also. What do you think, Jeff.:D
New EPG
my thought is that the tubes will need to be close togeather as the flux lines need to be closeto geather. ???
other than that, good find! looks sweet!
Hi Jeff some of my earliest memories are in an old Buick Special Station Wagon. I learned two important lessons Never kick the back of dads seat and always sit in the very back cause his arms werent that long. Great memories. Just had an out of box thought so I thought I would post it here if you dont mind. Saw a vid from Zero Fossil Fuel on some work he was doing with his Mueller Motor. He showed a big change in effeciency in an .008 space in the field!! With the Epg in mind I thought what if we used a styrene particle? I found a company that can custom make in different size, colors, luminos ect. Wonder if we could figure a way to pulse the particles bigger then smaller and create a moving magnetic lines with just some pulsing like a heart? I guess the styrene could be both a particle and a gas. Any thoughts anyone?
