PCB need help from a proffesional
mrusten
« on February 28th, 2013, 08:52 AM »
hello
i have a not completed design, and need help from someone that understand more than me.
i need a gerber file and someone to run a simulation.
i know its a simple circuit but its out of my understanding.
maybe someone have another solution on my problem: i have an electric motor that is connected to a massive gearbox so there is no amp draw, then i need it to have a specific newton meter on the shaft. i want to fit a spring and 4 switches to tell the pcb if the speed need to go up or down a little or fast
 its 4 switches in the diagram they are not spouse to be there because that will be 4 axillary relays to decide if the 4-20 milliamp loop need to increase or decrease
 therefor the 555 timer to make a oscillation with 2 speeds to increase fast or slow, the same for decreasing.
 the 555 timer control a digital potentiometer (1 pulse from 555 timer moves the potentiometer 1 step)
 and then the digital potentiometer is connected to a amplifier to make the 4-20 milliamp loop.
 this is for a electric motor speed control unit.
input voltage is between 24 and 28vdc
 voltage regulator for the 5vdc is missing
 i dont know if its necessary aether.
thank you.
