I have given this a lot of thought.
First, let's touch on the legality of leaching power through inductance.
As long as it is done after the meter and before the panel there should be no legal issues because you are leaching from the metered power that you are paying for.
So I tried a simple experiment, I wrapped a number of windings of speaker wire, probably 14 gauge twisted, around a lead cord of a 1500 watt cube heater lead cord, I didn't count the turns, I'd say about 10 feet. I produced less than a volt until I grounded the windings, then I got 3+ volts. Sorry I couldn't measure the amps.
So I'm thinking if I wind a coil around a wire carrying 220 volts and around 200 amps perhaps I could power an inverter and tie it in to the panel, perhaps I could leach some energy from the power I am already using.
