With PWM, you can get up to 7 or 8 different colors from the RGB Tri-Color
LED's.
I will see how it will works with these leds first:
3W 650 - 660nm
3W 405nm
3W 395nm
1W 365-370nm
LED's.
Thanks for the schematic Quantum, I want to play with this one, Jeff.Quote from Quantum on June 5th, 2012, 09:20 AM My current setup looks like this.Quote from Jeff Nading on June 4th, 2012, 08:25 AM Can you post your flyback circuit and how it connects to the flyback transformer,if you have it already? Thanks Jeff.:DQuote from Quantum on June 4th, 2012, 07:53 AM I agree, the 615 and 777nm are helping in the first electron removal from O atom so it will be ok for creating the O I as also the 645nm. For O II i would use 407nm. For O III 396nm. And for O IV 373nm. But every single led has effect on not jut one transition but for almost every transition from O I to O IV and this is good.Quote from nbq201 on June 3rd, 2012, 03:56 PM The "Gas Processor" was different in Ionizing Air
If it was for Oxygen then it would be in the peak 615.8nm range of Amber/Orange
LED's from the spectrum. It's been reported that Oxygen is at it's peak at 777.19 nm, also which is in the Longwave Near InfraRed scale, but it doesn't appear on the spectrum chart.
Now I am building my Air Ionizer with common elements what can you buy at stores. When its finished i will post my results. I am using flyback transformer around 125kHz for creating the positive corona discharge in a reflective tube in inside what will be illuminated by the LED's pulsing light on same frequency 125kHz but in 180 degree out of phase. For electron extraction will try out a few things for example a light bulb in series, resistive wire, dense screen mesh with steel wool or something like this. To test the ionizer i am planning to mix the ionized air and burn it with PB gas maybe, and of course will put it on some kind of engine air inlet witch will use regular fuel, sucking the air only trough the ionizer. I will also insert negatively charged fine water vapor in to the engine trying to minimize the benzine consumption. Now I am planning the driving circuits for the LED's, injector, temperature controller for the water heater before the injector, flyback drivers.
Using HHO with ionized hydrogen using 660nm leds in the resonant electrolyser is also a plan. So with all this together combined the water vapor, ionized air, HHO, exhaust gases I am hoping good results.
The strange thing is when I connect the UC3844 pin5 to GND it stops working. I have tried with UC3843, UC3845 without success... Its working around 125kHz and with low input current making nice corona discharge. My power supply is 17V.
United nuclear carries the best IR LEDS invisible to the eye.
smaller wave is good, any other wave such as a flash from a camera UV would cause a movment perhaps due to the dilectric properties of the gas, but also carries more energy.
I like the steady wave low frequency, and i high pulse of blue light for a kick.
But the high intensity of a laser would do a better job all around, because you can focus it on a reflector. Ionising radiation, same this is happening at the gap to a degree, because of heating.
It is possible that a laser pulse would heat the gas much quicker, wasn't it heat that caused the electrons to move to the outer rings? wasn't it the heat from a laser that ionized the air around the pulsed laser rocket? Stan had mentioned pushing the intensity up in several levels. that's why he stepped up the current in the conductor, and, or light intensity? laser pulsed because of heating, but hey IR is a heat source..
The energy in the electron of a hydrogen atom, are conditioned to add charge, or induce charge on tiny dipoles, and electrons. I think Walter lewin said lower wave lenghth, more energy in the photon emf. All by itself It will make a great fuel.
As an observer i find it amazing that unpolarized light has a radial field in all directions, due to photon radiation. And at 90 degrees to the source it becomes 100 percent polarized to the observer.
hope that helpes good stuff Russ. be cool.:cool:
Check this out:
http://www.energeticforum.com/showthread.php?t=19711
As soon as the scientists start calling electrons, dielectricity, many of the world's energy problems will be over.
Russ you have to add the light chamber to the arc reactor. the lights at the trigger itself,
well shielded, free of added heat, but in a reflected chamber.. the spark gap reactor. are you gonna post?
hey guys check this stuff out, sent to me by Jacob W, i have seen this a while back but it is so fun...
Hydrogen atom emulator :
http://astro.unl.edu/naap/hydrogen/animations/hydrogen_atom.html
also attached a photo he sent me. we have been over this but here i another diagram from NASA
enjoy!
As regards Meyer's gas processor (I think it's called), where he used LEDs... in my Energetic Forum posts, I derived the resonant frequency of the short O-H bond, it's up in the x-ray range... how about if, rather than hitting the water with light, we hit it with x-rays, given that the closer we can get to the actual harmonic frequency (as opposed to a subharmonic), the more effectively we can resonantly add energy?
How?
Miniaturized high-speed modulated x-ray source
A miniaturized high-speed modulated X-ray source (MXS) device and a method for rapidly and arbitrarily varying with time the output X-ray photon intensities and energies.
And from that YouTube video above, we could actually create a "water battery" by tapping the charge differential in water off a large number of plates, using it to charge a capacitor, then 'joule ringing' that up to a voltage that is usable in a conventional electrolysis cell. Water providing the power to dissociate water.
Or just use the tapped and stored electric energy directly as is, that would be some battery :thumbsup:
It'd be too low of a voltage to dissociate water directly, hence the suggestion of a joule ringer and capacitor.
| Configuration | Eadsorption | Edissociation |
| monomer | 0.48 eV | 0.51 eV |
| dimer | 0.55 eV | 0.20 eV |
| trimer | 0.57 eV | 0.01 eV |
| chain (2H20) | 0.59 eV | 0.17 eV |
| chain (4H20) | 0.59 eV | -0.10 eV |
| chain (6H2O) | 0.59 eV | -0.08 eV |
| chain (12H20) | 0.59 eV | -0.08 eV |
