Just had a thought... the basis behind the proton adsorption on a "groomed" platinum surface appears to be quantum tunneling... it's energetically preferred for the proton to be adsorbed into the platinum surface rather than being re-protonated by the water molecule due to the angle of the water molecule hanging off that platinum "terrace". We're essentially tricking the water by allowing it to undergo its natural process of deprotonation (which it does all the time as the water molecules swap hydrogens), but grabbing those protons before the water molecules can.
This leads to three thoughts... first, how can we make this process even faster? If we charged up the platinum surface like a capacitor to a large negative voltage (since protons are positively charged), that might do it, but that might also change the orientation of the water molecules hanging off the edges of those platinum "terraces", thereby destroying what we're trying to accomplish. Experimentation is in order.
Second thought... the protons quantum tunneling through the platinum will eventually reach the carbon fiber that I'd discussed using as a plate filler material to coat with platinum... and it's the protons in hydrogen that cause carbon to spontaneously rearrange into diamond... I'm wondering if that'd happen with carbon fiber, given that the carbon fiber is pretty well insulated by the bonding agent used in making the carbon fiber.
Third thought... if dry carbon fiber material were coated with platinum and used in an electrolyzer to gather those protons, that insulating bonding agent wouldn't be there... that might be one avenue to making large and molecularly perfect diamonds. There's no heat, no pressure, no contaminants to cause any occlusions in the diamond... you could literally make diamond glass sheets.
