RENAiSSANCE Φ RESoNANCE
« on September 18th, 2017, 06:38 AM »Last edited on September 18th, 2017, 07:06 AM
Escher
Simple Free Energy
https://www.youtube.com/watch?v=KvQOAY0DwgI
Yes that is good to hear about the I AM who I AM.
I'm not a stickler for language. There is a lot of work and care to be taken with clarifying terms. We talk about the capacity increasing in the battery itself over time with more cycles as opposed to decreasing with cycling which is normal. This can happen because 1. our charging can desulfate batteries and also 2. condition the batteries to receive more charge (harder to explain). So the charge capacity can be hard to compare when the battery can actually increase. So it is more than a function of voltage rise over time, but also a measure of real loads and fully discharging batteries over many cycles. Charge rate is simply how fast it is charging but not in Amp Hours or amperes. We can however measure the amps and volts of the discharge of the battery. But measuring the amps while the batteries are charging will give you a major difference of the actual charge rate because we are not charging with amps. The assumption is that you can only charge with amps and so these systems are wrongly evaluated from the start. But time will show with many cycles and load tests that something else is charging, and that changes everything.
This technology goes back to Tesla and many experimenters have played around with it over the last 100 years. I have my own angle on it.
Phi and the Equilateral Triangle
http://www.maths.surrey.ac.uk/hosted-sites/R.Knott/Fibonacci/phi2DGeomTrig.html
valKnUT
https://en.wikipedia.org/wiki/Valknut
MosFET I removed some of the older videos for various reasons. Most of the videos will be replaced by better ones in the future. The old and even some recent videos were done very fast without much effort for various reasons. Here is one video of the fan kit:
...https://www.youtube.com/watch?v=fBWHrn7IeaQ&t=0s
The fan kit can be 1 to 1 charging given the right size and condition batteries and setting to one of the sweet spots. Just remember as we show in our video that even 90% charge rate would take more than 100% to get a battery to that level, so 1 to 1 would be more than 120%.
Practically speaking if you ran a normal fan, or one of ours before you convert it, for 10W, you could instead run a fan for 10W and charge a battery at the same time to get around 10W out of it over the same amount of time. Or you may get less depending on size and condition of batteries and tuning. Anything more than that 10W is free. Rotating batteries around with a 90% recovery would amount to reducing the energy needed to normally run the motor so that you may only need to put out 1W over the same amount of time. We will be doing a heating system along these lines where you could plug in the wall and either draw only 10-25% of the normal energy to produce heat or charge batteries and/or run all your lights in your home at the same time.
https://nl.wikipedia.org/wiki/Kut_(term)
Vortex Based (female) Math
Unlocking the magnificence of the 3 6 and 9
https://vortex369math.wordpress.com/2013/03/13/10-ring-sets/
shazizz
A dead battery has exactly the same amount of energy as a full battery. The energy is simply divided equally to the materials natural balance. When there is an imbalance the battery is what we call charged. The work we get done is due to the flow as nature attempts to balance it back out again to what we call a dead battery. So by keeping an imbalance in the battery we can keep it charged. Same principle as water finding its own level. By controlling the flow we can slow down the balance. Resisters, diodes etc. are like water valves allowing to control direction and pressure.As long as you can keep nature from balancing back out you can get work done by controlling the flow. It is really simple. Using all the forces and external energy concepts such as the ventjury affect you can add to the imbalance and do what we call charging. All we are doing is using the force in the middle to get work done.
AVe
...https://www.youtube.com/watch?v=fb6tL64M4eg
http://andreasaronsson.com/
Nothing happens by chance
http://forum.keshefoundation.org/forum/the-keshe-forum/55510-nothing-happens-by-chance?p=63258#post63258
Re: RENAiSSANCE Φ RESoNANCE
« Reply #1, on September 20th, 2017, 05:25 AM »Last edited on September 20th, 2017, 12:25 PM
Ossie Callanan’s Free-Energy System
In 2007, Ossie Callanan published a document showing how and why he was getting COP>1 battery charging. Ron Pugh’s system kindly shared in detail above, with careful tuning and running on 24 volt input and 24 volt output operates at COP>10 which is likely to be due to Ron’s skill in building and adjusting, both of which are very good indeed, coupled with the use of many transistors working in parallel and tripled charging diodes to improve their performance. The John Bedini SSG pulse-charging system is very easy to construct and works very well, even with many sulphated batteries which have been discarded as useless. However, most people will not get COP>1 performance from their own SSG build. Ossie explains why this is in the following section which is his Copyright. He says:
I believe I may have this radiant energy system worked out to the point where anyone can build it and when you build all of it, it can provide you with free and continuous energy. There are two sides to the circuit and just having either side is no good, you must have both. One side is the pulse-charger side, and the other is the battery and accumulator-converter side. At present, I am charging batteries at a performance level between COP=2 and COP=10 and battery swapping is not a problem.
First we need to focus on the charger side of the system. Basically, you must build a charger which produces large amounts of radiant energy in the form of radiant pulses. Radiant energy pulses are Back-EMF pulses provided that they have very fast rising edges and falling edges and occur at high frequencies. They are not transistor transients or switching transients! A spark-gap produces classical radiant energy pulses. They are chaotic events but they are radiant energy events nevertheless. Switching a coil on very rapidly using a transistor will produce one radiant energy pulse from the coil’s Back-EMF, but one pulse on its own is no good. You need thousands or better still, millions of those pulses for them to be of any practical use.
John Bedini's Simplified School Girl motor (the “SSG”) only produces a very small amount of radiant energy when you have the base of the transistor tuned so that you get the longest self oscillating pulse train per magnet pass. It is not very efficient as the base-clamping diode wastes this energy, passing it back through the base resistor-bulb circuit but that circuit it is necessary so that you can synchronise the operation and provide a driving force to the passing magnet. Without the base-clamping diode, you get an oscillator and the motor won't turn - catch 22. But still, even when tuned with the base-clamping diode in place, the self-oscillating pulse train is usually at most 3 to 6 pulses which is not very much and so, not much radiant energy is produced. For all those people trying to tune the motor for only one pulse per magnet pass, they are wasting their time and only building a pulse motor and not an efficient radiant energy generator.
The SSG is not a very powerful or good radiant energy generator and apart from being educational, it is really a waste of time unless someone can explain to you how to tune it to get the greatest possible amount of radiant energy from it with a long pulse train, and then tell you what to do with that radiant energy. John Bedini's method of using a bulb in the base-feed circuit is to keep the motor tuned to a particular number of pulses in the pulse train per magnet pass or for the longest pulse train as the motor increases speed, also, the battery's impedance changes the speed as well. The two-strand coil where one coil is used just as the transistor trigger, along with the wasted energy in the base circuit, add to the overall inefficiency and make construction more difficult.
In saying that about the SSG I would like to show you now a very simple and basic pulse oscillator or motor driver circuit that you can build with off the shelf parts, one which will produce very large amounts of radiant energy when adjusted correctly. Here is that circuit:
Do not be fooled by appearances - this is as close to a controlled spark gap circuit as you are going to get and it is extremely efficient in the production of radiant energy! But most importantly, you must place and adjust the reed switch appropriately and properly!!! Take a look at this picture:
As you can see, the trick is to place the reed switch so that it runs along the length of the solenoid coil and so is located in the coil's magnetic field. This couples the coil's magnetic field to the reed switch as well as the magnetic field of the passing rotor magnet. This provides a magnetic feedback and turns the reed switch into an oscillator. So when the magnet passes the reed oscillates with the coil's field and causes very many pulses, typically 20 to 50 pulses per magnet pass. Amazingly, unlike the clamping diodes in the SSG, this is not wasteful. This reed switch oscillation actually reduces the input current. Instead of the reed remaining closed for the whole of the pulse duration, it switches on and off and so, less input power is drawn from the driving battery. I run the motor so that when the coil is energised, the magnet is attracted to the coil. Here is a trace across the charging battery:
The trace above is from a motor that is only drawing 50 milliamps but is charging the battery many times faster than if it were drawing 300 milliamps with a single pulse per magnet pass! But there is more. Take a look at the following picture:
Using a very small and weak magnet, you can now control and adjust the reed switch. This allows you to adjust the switching so that the circuit oscillates continuously but still powers the passing rotor magnet. Below, is the trace across the charging battery and the battery is charging very rapidly although you are still paying for this as the input current will increase but nevertheless, you are really producing a vast amount of radiant energy for what is effectively, very little input current! Also, when you do this, the coils HISS very loudly! Yes, the coils HISS, not with a tone or frequency but with a hissing NOISE.
My prototype motor uses four of these circuit's, positioned 90 degrees apart around the rotor, and all connected in parallel. You can use just one reed switch to switch all four transistors and coils but it is more load and the reed switch does not hold up for very long. In fact, either way, if you use small reed switches, they will get worn and start to stick. I have bought larger reed switches but I am also working on an electronic switching version of this, although that is easier said than done. I have worked on this for a few months now so I have tried very many things and have not managed to match it with electronic switching yet. Limiting the current passing through the reed switch does not necessary increase the length of its operational life, besides which, doing that produces less radiant energy.
Now having shown you all this, we are only half way to a complete radiant energy system which will provide continuous free energy. The above circuit and motor, even though they do provide large amounts of radiant energy, will still only give you a COP equal to, or close to 1 when regularly swapping over between the source battery and the charging battery. For battery swapping to work, you MUST have the second and equally important side to the system. The second side of the system is the radiant energy accumulator-converter.
Before I describe the radiant-energy accumulator-converter, I want to highlight how important it is to build and experiment with the circuit described above. Only after adjusting and watching the input current and how the charging battery charges can you truly see how these radiant energy pulses are affecting the charging battery. In terms of why it works or how it provides so much radiant energy you have to understand that if the reed switch stays closed, which will happen when they get worn and start to stick, with the 9 millihenry crossover choke solenoid coil (bought off the shelf) which I use, the transistor is turned fully on and at virtually it's lowest resistance and so the current draw is about 6 to 8 AMPS for a single coil circuit!!! It seems this is a key requirement for generating these radiant energy pulses with a transistor. You have to switch the transistor fully on at maximum current for the coil and input voltage. This is another thing the SSG does not do well. But yet, in this circuit, when the reed switch is adjusted correctly, you can get the input down to just a few milliamps if you want!
OK, now to the radiant accumulator-converter. The requirement for this appears to be because the charging battery is not very efficient at absorbing all of the radiant energy pulses. John Bedini had related this as being due to impedance matching but I am not sure of this at this stage, but impedance may be a factor. Because the charging battery does not absorb much of the radiant energy by itself, you MUST have an accumulator-converter to absorb and convert the radiant energy for the charging battery to use. Ok, that said, what is a radiant energy accumulator-converter?
A Radiant Energy Accumulator-Converter (“REAC”) is nothing more than a dipole! But the larger the dipole the better! The dipole can be a battery but that is silly when we are already charging a battery. Well in that case, it is a special battery. It is a battery that is mostly composed of potential but little current. The higher the potential the better the accumulation/conversion but some current is still required to be able to pass the energy back and charge the charging battery.
There are a number of traditional dipole's that fit what is needed. There is a simple long and raised wire antenna and ground, but this will not provide enough back current to charge our battery. There is an earth-battery setup, but unless you want to put in the effort and amount of materials to raise the voltage and still have some required current this needs a lot of work and materials. Finally, I found the best compromise to be "old, dead, sulphated lead acid batteries". At this stage of my research the condition of the battery does not really matter as long as it is “dead” and sulphated. As long as they are old and dead so that they can barely light up a 12V 100ma bulb, then they will do just fine. Gee I am glad I never threw away my old dead batteries that kept piling up.
If you go down to a battery recycler or junk yard, you can buy pallet loads of old and dead Uninterruptible Power Supply (“UPS”) batteries for very little cost. When I say pallet load, I mean pallet load. The bigger the bank of these you get the batter. Connect them both in series and parallel so that if they where good, you would get anywhere from 48-120 volts. When connecting in parallel make sure that each 12 volt segment has an approximately even capacity in Amp-Hours. You can put this bank under your house or table or even bury them in the ground. It is no problem as you will never have to do anything to them again (as long as they are sealed). They will NOT keep running down. They are already run down. All you need them for is to use their potential as a dipole and their hidden capacity. The very small amount of current they will provide for the size of the bank due to the crystalline resistance of the sulphation is all that is needed to provide the free energy that the will convert the radiant energy pulses and feed it back into your good battery which is being charged. I believe that these sulphate crystals may indeed be the main component that is doing the radiant energy conversion for us. Now for how to connect up your ‘REAC’. See the following diagram:
You must connect the REAC directly to the charging battery as I have shown above. Amazingly, there is a great voltage different when you measure the voltage directly across the charging battery compared to the voltage measured across the REAC while the reed motor is running. This voltage difference is seen even with thick cables connecting them, but distance does affect it as well. You must have two separate sets of cables. One set going directly from the radiant energy charger to the charging battery and the other set from the charging battery to the REAC. I have run the above setup for over one month now. Below is a picture of the “dead” batteries which I use as an REAC.
Using my good 33 Amp-Hour UPS batteries, I can charge them up from 10 volts to 14 volts in about 6 hours with the radiant energy reed motor running 4 coils drawing only 600ma. I can then swap the source battery with the charging battery and keep doing this until I have both batteries charged in about 24 hours. I have done this very many times and the charging rate appears to be improving over time.
But one thing I want to make clear. If you think that I am somehow just using the stored energy in the REAC bank, if I do not use my reed motor, then the charging battery will not charge. If I try replacing the reed motor with a regular battery charger, the battery will take as long to charge as a normal battery charger would to charge it. When using the reed motor, the REAC is converting most of the radiant energy and providing the energy back to the charging battery. There you have it, a fully working radiant free energy system. Enjoy! -- Ossie Callanan
http://www.free-energy-info.co.uk/Chapt6.html
Radiant Energy Plasma Generator & DIY-Circuit!
https://www.youtube.com/watch?v=eTlA8Ee6b0Q
And they were all filled with the Holy Spirit,
and began to speak with other languages, as the Spirit gave them utterance.
http://open-source-energy.org/?topic=1637.msg44327#msg44327
« Reply #3, on September 20th, 2017, 12:27 PM »
A REAC composed of dead batteries.  That's a novel idea.  How about big car radiators buried in the ground like Kapanadze used?
« Reply #4, on September 21st, 2017, 11:31 PM »
"Also, when you do this, the coils HISS very loudly! Yes, the coils HISS, not with a tone or frequency but with a hissing NOISE. "
humm... where have herd that before :)  bacon any one...
« Reply #6, on October 3rd, 2017, 05:42 AM »Last edited on October 3rd, 2017, 06:46 AM
GiF
2 4
GiVE
FIBONACCI YIN -YANG CIRCLES - Binary Division
We often associate the Fibonacci Sequence (1-1-2-3-56-8-13-) with Biology and Nature
and we often associate the Binary Sequence (1-2-4-8-16-32-) with Tech, Robot, Borg.
But interestingly, these apparent opposites are very elegantly and intimately connected
as shown in the full large circle (whose diameter 34 units)
that is then subsequently sub-divided into uneven parts
(the opposite of the Ying Yang Binary Sequence concept of equal midpoint divisions or continued halving)
where the 34 is divided into its Golden Ratio of 21 and 13 units,
and each of these circles are sub-divided into their Golden Ratios,
21 is thus proportionately partitioned with 13 and 8, and
13 is partitioned with 8 and 5, and so the process goes on,
revealing a powerful tapestry of beautiful circularly diminishing parts,
aesthetically and curvologically pleasing to the Eye.
Jain 108
https://www.facebook.com/permalink.php?story_fbid=298499220556809&id=100011901996265
The Dimensions of Paradise
http://blog.world-mysteries.com/science/the-new-jerusalem-diagram/
1+1+1=3 x 37 = 111
2+2+2=6 x 37 = 222
3+3+3=9 x 37 = 333
4+4+4=12 x 37 = 444
5+5+5=15 x 37 = 555
6+6+6=18 x 37 = 666
7+7+7=21 x 37 = 777
8+8+8=24 x 37 = 888
9+9+9=27 x 37 = 999
37/27 x 100 = 137
the fine structure constant
So why does CERN have a 27 km track?
https://kachina2012.wordpress.com/2008/09/14/cern-and-the-fine-structure-constant-137/
37 x 37 < one369 > 1370 - ONE
the MATRIX
...https://www.youtube.com/watch?v=0qeLR1V-Z_o
the CODE
...https://www.youtube.com/watch?v=Xw9lTB0hTNU
« Reply #7, on October 7th, 2017, 03:23 AM »Last edited on October 7th, 2017, 07:00 AM
https://www.youtube.com/watch?v=Mnoy2D4wuf8
don smith seminar on how to make it
Nodir D
vision of Teslas tecnology
https://cloud.mail.ru/public/JVAz/XjpXmX6Zi
If shortly, vision based on Teslas patent № 512340.
Common tesla transformers secondary coil consist of one layer. But in this version the secondary coil is bifilar, videlicet it consist of two layers, connected in series.
Between layers we have electrical field E=U/2 . If we put capacitor (two plates with dielectric between them) in this field, we will have electric charge separation (electric induction) in it. Load mast be connected to this “internal” capacitor. There is NO magnetic coupling between coil current and load (inner capacitor) current, because they are perpendicular! So there is NO electromagnetic feedback!
To better understanding read Teslas patent № 512340 and Donald L. Smith
http://www.free-energy-info.com/Smith.pdf
512340
6O9
96 + 42 + 42 > 180 rainbow
4 x 21 < 84 > 12 x 7
Jain 108 Mathemagics FIBONACCI YIN-YANG CIRCLES - Binary Division
https://www.facebook.com/jainmathemagics/posts/710911352427934
Bert Janssen Squaring the Circle and the Great Pyramid
http://www.cropcirclesandmore.com/geometries/200902pyr.html
WelcometotheGoldenPAge - Part 1
...https://youtu.be/eZUdVZlOsyg?t=3m30s
Thus, a rainbow is not an object and cannot be physically approached. Indeed, it is impossible for an observer to see a rainbow from water droplets at any angle other than the customary one of 42 degrees from the direction opposite the light source. Even if an observer sees another observer who seems "under" or "at the end of" a rainbow, the second observer will see a different rainbow—farther off—at the same angle as seen by the first observer.
https://en.wikipedia.org/wiki/Rainbow
This looks a little complex so let me try to explain.. If we scale the Earth with the Great Pyramid which includes the King's box to the size of the sun, the side of that box is now the length of the 3rd smaller pyramid, the inside front of the box is now the length of the center pyramid, and the space inside now relates to the Great Pyramid itself.
https://www.facebook.com/WelcometotheGoldenPAge/photos/a.501940609949207.1073741828.501928589950409/1016407158502547/?type=3&permPage=1
Marc Belanger: MBR Circuit A-02, Looped & Transformed Overunity Relay Charger
http://open-source-energy.org/?topic=3105.msg46286#msg46286
Why 33 ?
...https://www.youtube.com/watch?v=8kZMBHIThPo
« Reply #8, on October 7th, 2017, 06:57 AM »Last edited on October 12th, 2017, 01:23 PM
Quote from ~Russ on September 20th, 2017, 11:57 AM
nailed it... ~Russ
rUSs
2rUS
The eye cannot say to the hand, "I don't need you!" And the head cannot say to the feet, "I don't need you!" On the contrary, those parts of the body that seem to be weaker are indispensable, and the parts that we think are less honorable we treat with special honor. And the parts that are unpresentable are treated with special modesty, while our presentable parts need no special treatment. But God has put the body together, giving greater honor to the parts that lacked it, so that there should be no division in the body, but that its parts should have equal concern for each other. If one part suffers, every part suffers with it; if one part is honored, every part rejoices with it.
Now you are the body of Christ, and each one of you is a part of it. And God has placed in the church first of all apostles, second prophets, third teachers, then miracles, then gifts of healing, of helping, of guidance, and of different kinds of tongues. Are all apostles? Are all prophets? Are all teachers? Do all work miracles? Do all have gifts of healing? Do all speak in tongues? Do all interpret? Now eagerly desire the greater gifts.
...https://www.youtube.com/watch?v=8Q7Hk4zl-OM
One of the great mysteries about the Great Pyramid remained the apparently incomprehensible design of the GRAND GALLERY, a SEVEN LEVELLED, elaborate corbelled vault forming the upper half of the Ascending Passage leading to the KING's Chamber.
http://open-source-energy.org/?topic=2680.msg46361#msg46361
2160 x 7 > 15120 < 3 x 5040
1260 x 4 > 5040
84 x 60 > 5040
http://open-source-energy.org/?topic=3071.msg46288#msg46288
5040 has exactly 60 divisors, counting itself and 1
5040 is the sum of 42 consecutive primes
84 > 42 + 42 rainbow
1 x 2 x 3 x 4 x 5 x 6 x 7 > 5040
7 x 8 x 9 x 10 > 5040
"Plato, writing under Pythagorean influences, seems really to have supposed that the well-being of the city depended almost as much on the number 5040 as on justice and moderation."
https://en.wikipedia.org/wiki/5040_(number)
6O9
6 X 9 >  54
54 = the number of colored squares in a Rubik's cube
540 degrees = the sum of the interior angles of a pentagon.
540 miles = half the radius of the moon.
5040 miles = radius of the moon + earth.
Finding the frequency of a WATER molecule
http://open-source-energy.org/?topic=2836.msg46377#msg46377
Selfish Unthankful Circuits or Loving Giving Paths.
https://www.youtube.com/playlist?list=PLsiIKXpZfLKIscoaN1F8sYHWEywVyBvAy
« Reply #9, on October 16th, 2017, 04:51 AM »Last edited on October 17th, 2017, 06:34 AM
A man should hear a little music, read a little poetry, and see a fine picture every day of his life, in order that worldly cares may not obliterate the sense of the beautiful which God has implanted in the human soul.
― Johann Wolfgang von Goethe
1260 x 4 > 5040 < 84 x 60
Quantum Gravity Research: 3D Printing the Substructure of Spacetime
http://open-source-energy.org/?topic=2972.msg44232#msg44232
Music gives a soul to the universe, wings to the mind, flight to the imagination and life to everything. …
Geometry will draw the soul toward truth and create the spirit of philosophy.
― Plato
http://joedubs.com/musical-geometry/
The Spiral of Theodorus
https://sites.google.com/site/jbutterfieldmath378/investigation-4
Bode's Law Doesn't Bode Well for Us
http://www.mostlycolor.ch/2010/04/bodes-law-doesnt-bode-well-for-us.html
In the Timaeus, Plato gives a numerical construction which he applies to cosmology rather than explicitly to music. However, in the ancient world these subjects were highly interrelated; in building his cosmology, Plato uses musical terminology, and in fact seems to construct a "Pythagorean" diatonic scale. He first successively doubles the unity three times to obtain the numbers 1, 2, 4, and 8. Then he successively triples the unity, giving the numbers 1, 3, 9, and 27. He is using the principle of the primal tetrad, elaborated through a geometric series based on 2 and 3, the only two prime numbers among 1, 2, 3, and 4. The numbers 2 and 3 were thought of as the first two numbers (not unity), the primal Even-Odd pair, which produce all duality (2), and dialectic (3). (Plato notes that in order to synthesize the three elements of the dialectic into one whole, "force" is required, which makes the number 3 the representative of primal force).
http://www.ex-tempore.org/means/means.htm
The Christian Mystery
http://www.doyletics.com/arj/christia.shtml
Christ raises the beam out of the 'water' - of the astral plane - and crosses the brook (the path to the higher worlds) toward sacrificial death on Golgatha. Christ's sacrifice unites the three columns of strength, beauty and wisdom into one - the threefold human spirit consisting of Spirit Man (Atma, 'Boas'), the Life Spirit (Buddhi, 'Yakin') and the Spirit Self (Manas, M)
Proportion in Musical Scales
http://www.sacred-geometry.es/?q=en/content/proportion-musical-scales
http://forum.keshefoundation.org/forum/the-keshe-forum/59343-losing-track-in-the-forum/
Without the help of modern technology, the ancient Egyptians managed to center the location of the Great Pyramid in relation to the entire globe. The ancient-code.com article confirms the following: The east/west parallel that crosses the most land and the north/south meridian that crosses the most land intersect in two places on the Earth, one in the ocean and the other at the Great Pyramid.
The Great Pyramid is also closely associated with the mathematical elements of Pi and Phi.
New research moving toward Plasma Fields.
http://forum.keshefoundation.org/forum/keshe-foundation-study-group/health-aa/59461-new-research-moving-toward-plasma-fields
...https://www.youtube.com/watch?v=GiBQjhKBlhg
The great pyramid of Gizeh [Giza] is a symbol of the temple of man in which his soul lives and ripens thru [through] experience to ascend thru [through] apparent solid matter to divine regions of its own.
http://www.digitaldrstone.org/v1b2c12.shtml
The angle of 26.5º in the ‘Ancient Geometric Formula’ from which the side angles
and cross-section internal features of the Great Pyramid were derived.
http://garyosborn.moonfruit.com/#/diagram-of-the-earth/4589566936
THE SEAL OF SOLOMON
http://forum.keshefoundation.org/forum/the-keshe-forum/61507-a-bright-new-forum
The golden spiral is in the golden rectangle,
which is contained as a diagonal surface in the icosahedron, and thus also in the Metaeder.
https://www.mi.sanu.ac.rs/vismath/schulze/METAEDER/metaeder1/GEOMETRIE/spirale/index.html
Numbers Are Real
Giordano Bruno Amoris
https://www.youtube.com/watch?v=-N8QiyJU_SY
PATTERNS OF ETERNITY - MALCOLM STEWART
https://samissomarspace.wordpress.com/
It is this ninth realm where we stumble on ‘squaring the circle’, the realm of Sophia. The last step, into the capstone, we cannot do ourselves because of a lack of duality. There is no difference between here and there. Source has to absorb us into realm ten.
http://www.cropcirclesandmore.com/thoughts/200803snt.html
http://forum.keshefoundation.org/forum/spirituality/spirituality-aa/58079-blood-is-a-very-special-fluid
CHARTRES
« Reply #11, on June 7th, 2019, 08:53 AM »Last edited on May 20th, 2022, 01:21 AM
CHRIST RULES
Our humanity has the task of transforming the whole mineral world into a pure work of art. Electricity already points for us into the occult depths of matter.
https://open-source-energy.org/?topic=3134.msg52920#msg52920
The separation is a very definite event, that one can follow; we will now have to be satisfied, however, with [just] indications. We are dealing, then, with male-tinged wisdom in the woman and female-tinged wisdom in the man. This female-tinged wisdom is passive, suited to receiving, listening, watching — to taking in from the surroundings. The male-tinged wisdom, the active wisdom, [is suited to] being productive. Thus we have a two-fold wisdom; the female wisdom that is active and that naturally will also be transferred to the men. So that there may indeed be plenty of men who take over the female wisdom, the race [propagates] itself below [on the physical plane]; and above, we are dealing with an active intuition stemming from women, and with a passive cognition, decidedly male in character.
FREEMASONRY AND HUMAN EVOLUTION
https://wn.rsarchive.org/Lectures/GA093/English/RSP1985/19051023p01.html
Heat/Resonator Circuit 001 Induction heater , Zero/ Voltage/s ....and haet element Driver !!!
https://www.youtube.com/watch?v=8_AK4HuG5FA
Consider that Hiram-Abiff was brought before the original father of his race. He was told that Jehovah was the enemy of the Sons of Fire. Who are the Sons of Fire? They are those who could only come into existence after the separation of the sexes, through the penetration of a physical female by a physical male. Fire is the active principle in the male semen. In male semen lives fire, in the occult sense. Jehovah had to create this basic force, so that the race could propagate itself. Jehovah created the Sons of Fire, which was only possible on the basis of this [occult] fire. Hence he is the opponent of change. He it was, who cherished [?] the old kind of propagation. For it was an expedient [?] which had been created, and therefore he turned again to the priests and made them into his preachers. He caused the power and the glory of his own wisdom to be proclaimed through the priestly wisdom; through the priestly wisdom, Jehovah's wisdom came to be made known.
Pure Hydrogen production Plus excess energy from one unit !!!
https://www.youtube.com/watch?v=kGCSxhZiZao
RESONATING MAGNETICS FIELDS AT WORK IN THIS CELL
https://www.youtube.com/watch?v=6shXUeFUjQ8
« Reply #12, on October 27th, 2020, 01:48 PM »Last edited on October 27th, 2020, 02:03 PM
DUAL SLIT EXPERIMENT. Fundamentals, Details & FACTS
https://www.youtube.com/watch?v=scmRiJFY51I
SINGLE SLIT EXPERIMENT: Part 1 Dismissing "wave particle duality" Quantum Quackery
https://www.youtube.com/watch?v=qpcQNYa3VZ8
NEEDLE EXPERIMENT: Part 2 Dismissing "wave particle duality" Quantum Quackery
https://www.youtube.com/watch?v=rpz3xOZ0dyY
Debunking the famous "Double-Slit Experiment", the basis of quantum & GR
https://www.youtube.com/watch?v=HZm43BfNvt4
« Reply #13, on February 26th, 2021, 06:42 AM »Last edited on February 26th, 2021, 07:32 AM
7eVen heVen
What Does Acoustic Interference Look Like?
https://www.youtube.com/watch?v=-bOij4uPQ7s
The Primer Fields
...https://youtu.be/9EPlyiW-xGI?t=1232
Visualizing Ultrasound with Schlieren Optics
...https://www.youtube.com/watch?v=MBPh410Gne
https://www.facebook.com/permalink.php?story_fbid=1026732954400095&id=100011901996265
Schlieren Imaging Systems
...https://youtu.be/JonG86KrxCM?t=84
TORUS
 154224220_1026769361063121_6662730636788557746_o.jpg - 285.41 kB, 2021x1796, viewed 105 times.
