bifilar side by side coil, as tesla turbine
«  »Last edited
a bifilar coil at resonance can store energy.
the resonant sine can also be seen outside the coil when metal objects are probed.
So i wonder is there a ether flow around the resonant bifilar coil?
In the tesla turbine patent:
https://teslauniverse.com/nikola-tesla/patents/us-patent-1061206-turbine
several parallel plates with holes in the center are used. so could this translate to an ether turbine?
Re: bifilar side by side coil, as tesla turbine
« Reply #1,  »
as I already had 3 of these bifilar coils stacked, I measured them.
each had .46mH inductance
but when parallel stacked connected, the inductance was .35mH
I expected the inductance to be a lot lower. how does inductance normally behave with parallel coils?
the resonant frequency was lower, around 900khz, while the separate coils resonate around 1200khz
i used the back emf off the ferrite rod stepuup transformer, again no magnetic field at resonance.
I tuned in the resonant frequency from high to low. this time with added parallel capacitance of 10nF.
the sinewave was not a perfect sine. a bit pointy on the minimum.
the resonance jumped when i was close the the frequency.
maybe this is due to the slight differences between the coils.
