brunozr
« Reply #475, on November 13th, 2016, 05:22 AM »
Quote from jbignes5 on November 4th, 2016, 01:21 PM
Russ you can get rid of the problem of ozone creation by submersing the coil in mineral oil. That would allow you to go beyond the ozone creation barrier. But I hate to be a stickler about this, using AC as the input is very dangerous. It is destructive to all life and materials. Using the impulse method can make this very very stable and safe since the impulses only go in one direction they energize the secondary and not oscillate it. You should get a DC output or DC like.
 There is a very good reason they shield microwaves, try to remember that.
 If you parallel the output coil you should get way more output in amps. That would mean you series the primary. Think of it like a transformer. Gauge also helps in that but try to balance the weight of the primary to secondary exactly or breakdowns will occur between the primary to the secondary. With an oil bath a lot of the problems will disappear since oxygen and other elements in the air can not interact with the coil and ruin the insulation. Try to remove all air around the coil. Either boil it or use a vacuum to remove the air from the immersed coil.
hi Jbignes5, do you have the schematic for this DC pulsing input? i d like to try this, but i dont know ho to do. my coil is ready. i will probably make some tests this week.
thank you
bruno
« Reply #476, on November 21st, 2016, 05:40 PM »Last edited on November 21st, 2016, 06:39 PM
hi friends
i had good results in my first attempt.
i dont have professional equipment. the measurements are NOT RMS... but we have to start somewhere.
i could measure the output before the caps only as shown in the picture.
in the coil:  32v x 0.61 amp
out the coil  64v x 0.71 amp
7000hz
36x36 rodin coil (36 slots)
22 awg x 24 wires (12 connected +12 open ends) each coil
wires in series
cap 500v 0,75uf
home pc scope
smartphone function generator
i ill send a video and pictures soon.
i d like to know how to do a DC pulsing circuit to try DC input and output with a bridge rectifier.
any suggetion? i dont know how to do it.... yet.
lets go !!!!
peace
bruno
« Reply #477, on November 21st, 2016, 06:00 PM »
pictures...
« Reply #478, on November 21st, 2016, 06:08 PM »
the traces on the scope
IN : green
OUT : red
the next picture is the smartphone function generator
« Reply #479, on November 21st, 2016, 06:47 PM »
i could not read amperage between the caps and the lamp.
was it too low???
tha lamp was on but not full power.
next i will try to use a rectifier and straight into a battery and measure dc input into the battery.
peace
bruno
talisman
« Reply #480, on November 21st, 2016, 09:19 PM »
Hi again,
Yes that is in the range of the starship coil DC testing I have been doing.
The measurement is OU but how to usefully extract the result.
How much power is required to maintain the condition
Will a draw also drop downward the OU are questions.
A motor-generator arrangement I think needs more than 100% OU to extract useful power
while running.
I am also trying to determine if coil and self looping OU does rise with power levels and
if so proportionally or at some other rate.
Also found some caps at a recycler for $1 each but thought they were too high 200VDC 3400MFD could give
them a try as well.
I have no idea the Hz just started using a lab DC power supply but could use some pointers on the expected
behavior I was told it was current limiting by the trained. Yet I see contradictions on the power supply levels
shown.
« Reply #481, on November 21st, 2016, 10:01 PM »
nice work guys,
please be ware,
unless you do power factor calculation OR convert the output to DC and the input to DC and measure there,
don't trust the ac measurements.
I have been able to correctly measure the ac IN/OUT,  and yes there is OU in the system, but i have not been able to extract it.
still looking to do more when time allows.
until then KEEP DOING GOOD WORK!!!!
« Reply #482,  »Last edited
Yep. It's been a while. And I spent the last year and a half or more trying to figure this out.
I can get 2.5kv p-p with a 100v p-p input. But how do I extract that energy with out messing up the LC circuit.
Well the answer is easy. Don't let current flow. Hummm OK. Open loop it is. Strangely using diodes. Coils.  Diodes. (Cap)?  FWB. Filter cap.  DC-DC converter. Solar charger.  Battery charge.
Because its open. One could run from the battery while charging.
Now I have  new ideas. Theses notes are just place holders to the experiments. If I don't get to theses with in a week some one jump. On my but.
Inspiration : http://open-source-energy.org/?topic=2927.msg46027#msg46027
And:
http://open-source-energy.org/?topic=3073
« Reply #483,  »Last edited
Ok late Nite in the shop proves to at least be helpfull.
Here we are and finaly we have the 220v AC/DC -DC
Powered on. I'm pulling 1amp from it at about 11.6v powering s DC fan. Not quite what I was looking for but it's a start.
More to do for sure.
What we basicaly ended up with was a an LC circuit as noted in my 800w experment 3uf cap. But we used the other coils with 9uf cap in the same configuration.
I'll need to draw it up.
I know the amp will put out about 65-70 watts max 100vp-p. I did not have the good scope so I took mesuremmets over the I insulation. Not as helpful just a signal though.
Attached are some. Photos. Took some tuning to get it to settle in at about 200ish volts going in to the power supply.
The fan would. Pull it back down. So it's verry un stable.
I recorded a video and the live stream. So I'll post those when I get time.
Also adding dioeds to the coils like I have in my fig #1 on the last post dose. Not work. No current flow = no magnetic feild coupling. However I was able to get some open ended coil stuff to work. So whats the difference.?  Not sure yet but just a note.
« Reply #484,  »
« Reply #485,  »Last edited
"Holy Crap"
https://www.youtube.com/watch?v=N8dUuaYpWd0
This IS NOT INDUCTION. THIS IS POTENTIAL DIFFERENCE oscillation.  THERE IS NO CURRENT FLOW???
how can it flow its a coil and cap????? its an open system!!!
no current = no magnesium = no induction ?????  this is only a Potential Difference Transformer...  its a Dielectric Transformer.
 Now on my setup its has a FWB on the one side but it cant pass current back to the coils. so when i get home ill try it with out so its completely open. the result should be identical.
« Reply #486,  »
Bingo !!
The dielectric field simply jumps to a new endpoint; that potential has no speed limit either.
« Reply #487,  »
The only thing i can think of is that the current rushing to fill up the cap... thats the only place current can flow but its never " closed" there's a cap in there...
why do i say that? because you can indeed measure a magnetic field... ???
so this current oscillation can then generate a magnetic field?  or is it just potential ( voltage) only flowing???
« Reply #488,  »
This is a tough question to answer Russ.  It's my feeling electrical energy can be separated into dielectric and magnetic components.  I also suspect these components can be recombined to form normal electricity.  How that is done?  I'm not real sure.  I think we would need to visually see what electricity actually is; how it's wound together.
Nelson has stated the back EMF from a coil can be temporarily stored in a cap and then pulsed back into another coil.  The first coil creates a magnetic field, but the second coil does not.  I always assumed this is because the second coil is pulsed with high voltage--I think now there is more to it than this.  The energy collected from the back EMF is different than charging a capacitor to the same voltage by a typical power source.  The thought Evo and I had is the magnetic field is left behind in the first coil.  The capacitor seems to be able to store whatever you give it and doesn't convert or transform the electrical energy into some standard type.  Whatever that form is, it can still be pulsed into a coil with typical semiconductors.
If done correctly, Nelson indicates the first coil that creates a magnetic field can be mixed/combined with the voltage pulsed into the second coil.  What do we have?  Volts time amps in a new relationship which has much higher power than we started with.  A remixing of the dielectric field with the magnetic field.  Sounds simple, but is still elusive on the bench.  The first part is easy.  I can dump current into the first coil, create a strong magnetic field and collect the back EMF into a capacitor.  Pulsing this temporarily stored back EMF energy into the second coil at the proper time with the two coils properly aligned still has me scratching my head.  It seems so easy, but just hasn't shown me what I'm looking for.
haxar
« Reply #489,  »
Here are my notes:
Before current flows, which takes time, the reed switch is closed.
At the time of closure, you get a BEMF spike as L.M.D. waves instantly, then with _time_, you have current or charge potential dissipating from the cap as T.E.M. waves, if kept closed.
Make a circuit that oscillates and creates BEMF spikes _before_ the potential runs out.
Implement a feedback oscillator circuit.
« Reply #490,  »Last edited
Torus/FlowerOfLife
https://www.facebook.com/jainmathemagics/posts/709440555908347
Van Gogh's Starry Night Illusion - AMAZING
https://www.youtube.com/watch?v=oDHPh4CtdY4
To make a very long story much shorter, I suddenly perceived that there must be an intrinsic 60 degree relationship within the water molecule itself which had to do with the 2 atoms of hydrogen and the 1 oxygen atom. This mystical realization of mine was subsequently affirmed and proven by several scientists.
https://www.facebook.com/photo.php?fbid=791986934259561&set=a.142611492530445.12206.100003447866617&type=3
RENAiSSANCE Φ RESoNANCE
http://open-source-energy.org/?topic=3071.msg45918#msg45918
Cut The Knot
Golden Ratio in Geometry
https://www.cut-the-knot.org/do_you_know/GoldenRatio.shtml
The Unity of Geometry - Everything is Energy
https://www.facebook.com/Nassim.Haramein.official/posts/703771539814107
2O18 > O 1 2 4 8 16 32 64
« Reply #491,  »Last edited
Numbers are REAL
https://www.youtube.com/watch?v=GiBQjhKBlhg
https://i.pinimg.com/originals/e9/b0/4a/e9b04a84fb0cc65d44688dfe66cb1980.jpg
The so called "sogwendel" by viktor schauberger reconstruced by felix hedinger
is a vortex like construction in the shape of a shell that is able to pump and energize water
https://www.youtube.com/watch?v=xGQ3GspbnVg
1 x 2 x 3 x 4 x 5 x 6 x 7 > 5040
Decoding The Gematria Of The English Alphabet
https://grahamhancock.com/leedsm1/
CALCULATE
http://www.martyleeds33.com/
7 x 8 x 9 x 10 > 5040
84 x 60 > 5040
http://open-source-energy.org/?topic=3071.msg46288#msg46288
1260 x 4 > 5040
2160 x 7 > 3 x 5040
One of the great mysteries about the Great Pyramid remained the apparently incomprehensible design of the GRAND GALLERY, a SEVEN LEVELLED, elaborate corbelled vault forming the upper half of the Ascending Passage leading to the KING's Chamber.
http://www.ancient-wisdom.com/Ghizaarchitecture.htm
“It seemed like a building let down from heaven, untouched by human hands.”
http://www.bibliotecapleyades.net/piramides/laspiram/laspiram03.htm
Mystery of the Great Pyramid missing capstone
http://forum.keshefoundation.org/forum/keshe-official/announcements/56192-the-140th-knowledge-seekers-workshop-will-be-thursday-october-6th-2016?p=56230#post56230
"It took Keely eight years to perfect the Trexar and the Trexnonar (Trexar used with nine nodes, the first three of silver, the second three of gold and the third three of platinum). He states that during the time he was perfecting the Trexnonar the intermissions of vibratory transmission through the wire were so frequent and of such length, preventing continuity of mechanical motion, that he was about to give up when a seeming accident revealed the truth of his former theory of the law governing the atomic triplets in their association. He states that compound negative vibration of the neutral centers of the molecules in the Trexar and Trexnonar causes antagonism by differentiation and the attractive power of aggregation becomes radiant force with immense rotational velocity, carrying the "force" beyond the molecular inner one-third sphere of coincidence.
http://www.svpwiki.com/Trexar
Numbers and Geometry in the Bible
http://dcsymbols.com/numbers/numbers.htm
http://soulhiker.com/7-things-you-must-know-to-become-a-free-thinker/
« Reply #493,  »Last edited
In light we must speak of a fourth dimension;
it can extend itself in a fourfold way;
it has the quality of inwardness as a fourth dimension.
BORROMEAN RINGS
RING TWO:
an elixir of memory & wisdom
http://yzygy.blogspot.nl/2010/06/borromean-rings-23.html
THE MYSTERY OF THE TETRAGRAMMATON (Part 1)
https://deephighlands.wordpress.com/2012/03/31/the-mystery-of-the-tetragrammaton-part-1/
Mark Chapter 6
http://dcsymbols.com/design/mark6.htm
The Pattern
http://dcsymbols.com/mastersquare/page9.htm
Pictures
https://www.google.nl/search?q=site:dcsymbols.com+dcsymbols.com&safe=active&source=lnms&tbm=isch&sa=X&ved=0ahUKEwirsLPsloDXAhXKExoKHeJtB_MQ_AUICigB&biw=1164&bih=809
SACRED GEOMETRY
http://esasabove.tumblr.com/post/100786969085
The Reappearance of Christ in the Etheric
Question: What is the relationship of chemical forces and substances to the spiritual world?
Answer: There are in the world a number of substances that can combine with or separate from each other. What we call chemical action is projected into the physical world from the world of Devachan — the realm of the harmony of the spheres. In the union of two substances according to their atomic weights, we have a shadowing of two tones of the harmony of the spheres. The chemical affinity between two substances in the physical world is like a shadowing from the world of the harmony of the spheres. The numerical ratios in chemistry are really an expression of the numerical ratios of the harmony of the spheres, which has become dumb and silent owing to the densification of matter. If one were able actually to bring material substance into etheric dilution and to perceive the atomic numbers as the inner formative principle, one would hear the harmony of the spheres.
Oppenheimer eYe
Quotes out of Hinduism's Bhagavad Gita....
...https://www.youtube.com/watch?v=ZuRvBoLu4t0
We have the physical world, the astral world, the Lower Devachan, and the Higher Devachan. If one thrusts the body down lower even than the physical world, one comes into the sub-physical world, the lower astral world, the lower or evil Lower Devachan, and the lower or evil Higher Devachan. The evil astral world is the province of Ahriman and the evil Higher Devachan the province of the Asuras. If one drives chemical action down beneath the physical plane, into the evil Devachanic world, magnetism arises. If one thrusts light down into the sub-material — that is to say, a stage deeper than the material world-electricity arises. If what lives in the harmony of the spheres is thrust down farther still, into the province of the Asuras, an even more terrible force, which it will not be possible to keep hidden very much longer, is generated. One can only hope that when this force comes — a force we must conceive as being far, far stronger than the most violent electrical discharge — one can only hope that before some discoverer gives this force into the hands of humanity, human beings will no longer have anything immoral left in them.
Question: What is electricity?
Answer: Electricity is light in the sub-material state. Light is there compressed to the utmost degree. An inward quality, too, must be ascribed to light; light is itself at every point. Warmth can extend itself in the three dimensions of space. In light we must speak of a fourth dimension; it can extend itself in a fourfold way; it has the quality of inwardness as a fourth dimension.
Question: What happens to the earth's corpse?
Answer: As the residue of the ancient Moon evolution we have our present moon that circles the earth. Similarly, there will be a residue of the earth that will circle Jupiter. Then these residues will gradually dissolve into the universal ether. On Venus there will no longer be any residue. Venus will manifest, to begin with, as pure warmth, then it will become light, and then it will pass over into the spiritual world. The residue left behind by the earth will be like a corpse. This is a path along which man must not accompany the earth, however, because he would thereby be exposed to dreadful torments. There are, however, many beings who will accompany this corpse, since they themselves will by that means develop to a higher stage.
    Reflected as sub-physical world:
      Astral World ............. the province of Lucifer
      Lower Devachan ........... the province of Ahriman
      Higher Devachan .......... the province of the Asuras
http://wn.rsarchive.org/Lectures/ReapChrist/19111001p02.html
The Vortex Maths - Marko Rodin Thread
https://forum.davidicke.com/showthread.php?p=1062969973#post1062969973
« Reply #494,  »
note all below text is my view of what we may be missing with this " coil shorting" in the secondary... and the result of 1000's of amps of magnetic flux. feel free to bash and tip apart theses thoughts. however... think hard about what I'm saying and do a lot of research to see what I'm saying... if its wrong... well OK. but have a look:
I posted This Topic as i was researching if there was a way to couple devices from afar.
The one I really wanted was to see what was to be done about capacitive coupling. ( rather than EM or inductive)
what i discovered what that there are ways to get away from the inverse square law. using only magnetic and or capacitive coupling.
The other reason I wanted to look at what else there was out there on the subject was due to the Rodin coil testing. it seems to be doing one or the other or BOTH.
so the next trick is how to magnify this effect? ( thanks Matt for this thought, it still needs verification but its a start)
 well if we can " pump" a magnetic field...  but rather than resonance... ( back and forth between a cap and an inductor) we use a one way fly wheel...coupled  with a magnetic resonant transmission system. + if we leave the transmitter open... we can also add capacitive coupling. ( one wire i can already do this no prob on my setup)
so what do we have well... we have ezcataly what 007 calmed to have. ( a shorted set of wingdings... where do you think all that current came from in the loop current meter????) I think the missing component was a diode in the sorted line??? or something that let the closed coil to keep building the magnetic field... ( in one direction only)  This is different then resonance. how?
 well the fact that resonance will only go as far as the resistance will let it. ( back and forth)  But you should be able to pump a magnetic field until some other force slows it down. i don even know what this is... resistance should be one of them.
i also dont know how this pumping action can be.
If this is true then this is it. if its not a diode in the circuit... what else would let this happen with in the closed loop.? this allows the resonance to happen but let the flywheel to build a magnetic field bigger than what possible normally?
Tesla's "magnetic amplifier" ? its not the same thing as resonance amplification.. its "magnetic amplification" ( current right? )
all this and now what...
well a test would be needed. will get there but for now... ( i did test a diode in the short and no good... also a DC bias... no help. it kills the resonance. )
think about this... something i have been pondering for a while now. you have one system in the middle of the room, it is at resonance,
You have another coil in the room that is the same resonant frequency. its picking up this resonance ( just as magnetic resonance wireless transfer is)
it WILL resonate and produce power just as the MIT reports.
so what... well there not coupled in a way that the pickup will drag down the primary driver... add as many resonant pickups as you want in the room till you over come the losses in the system...
i have always asked. is it possible to add more pickups in a room with out effecting the transmitter?
well not if there inductively coupled... however the answer should be yes if its magnetic resonance coupled....
place 1000 tuning forks in a room. now drive 1 at its resonant frequency.. guess what... yeah thats right. the rest will start moving too... and it should not be at the inverse square law... ( some one else tell me if i'm wrong here)
Sympathetic resonance.... what rules dose this fallow?
ok well for now those are some thoughts.
I did test the system last night with no help. so what other ways can we " flux pump" the Rodin coil short with out messing things up?
also note that the coil goes in one direction...
https://www.youtube.com/edit?o=U&video_id=FCWXZzN9X7c
ok, some notes / questions.
should we drive the coils at there 1/4 wave length? To isolate the system better or other reason?
can you "pump' a dielectric field? dielectric pumping and magnetic pumping?
how long dose the magnetic flywheel last? think ed's PMH????
Look up laser sabers shorted coil PMH Ect.
https://www.youtube.com/watch?v=r9Kg69cQteg
similar to marks TPU?
