hey guys, so i have been doing a lot of research. one thing is that i want to use CR-39 to detect Tracks from alpha particles.
its Quite simple and with some trial and error i was able to get Clear results and some good data from my testing, i will be publishing a video on this in more detail but for now here is the results:
the failed results:
http://open-source-energy.org/rwg42985/russ/cold%20fusion/CR-39%20Particle%20Decay%20Track%20Detection/RWG%20-QGR%20CR-39%20test%20Procedures%203-18-16.pdf
the good results:
http://open-source-energy.org/rwg42985/russ/cold%20fusion/CR-39%20Particle%20Decay%20Track%20Detection/RWG-QGR%20CR-39%20test%20Procedures%203-22-16.pdf
anyone can do this its Cheep and simple Nuclear decay detector. AKA radiation decimator
thanks,
the failed results:
the good results:
thanks,
