I don't think you will find a document where Tesla says he can trnasmit totally without loss. He did say minimal losses like less than 3 or 5% but the important part of that was that he could transmit it around the world with extremely low loss and without transmission lines. And he said that any energy extracted by the receivers would need to be pumped back in by the transmitters but that the system once started and brought to resonance would idle at very low power usage, i.e. that 3 or 5% loss.
The spark gap was the diode of Tesla's day. It allows current to flow only one way and it will handle enormous voltages and he was talking of using upwards of 20 million volts. The unidirectional aspect of the spark gap was what was critical to creating the impulses and a quenched spark gap would give faster fall times to the impulse. The impulses are not DC and they are not AC.
Later he learned how to do it without the spark gap but it's very tricky to get right. It involves the charge rate of the cap, the the timing of the discharge, and the discharge rate. By having the discharge rate be very slightly faster than the charge rate and the discharge occurring at the top of the charging cycle it became only necessary to "top off" the capacitor to get the the next discharge. I never saw it explained this way but I think that's how he got his very low loss transmissions, the loss being that difference between charge and discharge rate.
He explained it like this, "The ideal medium for a discharge gap should only crack … think for the sake of illustration, of a piece of glass or similar body clamped in a vice, and the vice tightened more and more. At a certain point a minute increase of the pressure will cause the glass to crack. The loss of energy involved in splitting the glass may be practically nothing, for though the force is great, the displacement need be but extremely small."
Experiments with Alternate Currents of Very High Frequency and Their Applications to Methods of Artificial Illumination delivered before the American Institute of Electrical Engineers at Columbia College on May 20, 1891.
The elevated sphere is the capacitor but you have to understand that the charge is accumulated in the dielectric surrounding conductor. So in this case the dielectric is the air surrounding elevated sphere. See the MIT demonstration of a Leyden jar and Fritz Lowenstein's paper on capacitances.
MIT - Dissectible Capacitor (The video's owner prevents external embedding)
Capacitances by Fritz Lowenstein
Exactly. With the proper timing and the impulse traveling to the opposite pole and reflecting back the pulses create constructive interference and reinforce the pulse train. What he developed was a way to create lightning and control its strength and timing and always have it strike the earth at the sam point - the ground connection of the Wardenclyffe transmitter. That's why he had the underground radial pipes at Wardenclyffe and said that his device "must get a grip on the earth." See his Colorado Springs notes of July 4, 1899.
Click here and scroll down to July 4
I've built one of his radiant energy collectors. It's interesting but it supplies only minute power in my location. Tesla said the energy collected would be dependent on the size of the elevated, insulated plate. I believe the amount collected is also dependent on the elevation above sea level since the higher the altitude the less air is between the collector and the radiations coming from space, whether from the sun or from other suns or celectial bodies. I got some really anomolous readings. At the time I was just collecting voltage readings and local environmental parameters, i.e. temperature, relative humidity, cloud cover percentage, etc. I couldn't find any correlation between the voltage readings and the local environmental data. After thinking about it a while I thought about space conditions, i.e the solar wind. The solar wind isn't constant but pulses and has constantly varying density and speed. Bingo. I found an inverse relationship between the solar wind density and the voltage readings. Out of around eighty readings I had three outliers so I think it's a pretty good correlation. I liken the solar wind density to a cloud passing between the sun and a photovolatic panel. The higher the density of the solar wind, the more radiant energy is absorbed by the charged particles that make it up. The lower the density of the solar wind, the more radiant energy strikes the elevated, insulated plate. Another correlation is that while the readings were lower at night, they were more constant. This would be the radiant energy not coming from the sun but other celestial bodies but it isn't affected by the solar wind because the charged particles of the solar wind aren't between those source and the collector.
Solar Wind Visualization
Space Weather - Good place to gather data
I also had a very interesting experience one night. There was a thuderstorm north of me but it wasn't raining in my location. I was taking a voltage reading and a cloud to cloud lightning bolt appeared and lit up the elevated plate. The insulation wass white high density polystyrene (not foam) so it was quite bright. The voltage reading jumped to 4 times the reading at the time and decreased over about 10 seconds. I wasn't quite sure what I was seeing so didn't think to count the seconds between the light and the thunder. A little research showed that lightning does indeed emit some x-rays and gamma rays. Search "dark lightning". My conclusion from my research points out that the major problem with extracting electrical charge from the atmosphere is that the energy density is just too low to be useful. With my results I calculated that I would need roughly 20 acres of insulated, elevated plate to power my home. The problem is that the collection rate is so slow with small collectors that about the only think you can do with it is charge a cell phone battery. There's no doubt that one could collect a large amount of energy but it would be depleted very fast in actual use. Maybe combining it with photovoltaics would be useful since it does collect some energy at night but I doubt it would be cost effective.
There's another interesting prospect about his work. The patent that covers transmitting through natural media states that the energy would be transmiited between tethered balloons at 30,000 feet which he considered relatively low. His initial idea was to transmit at 15 miles high which works out to 79,200 feet. His Colorado Springs notes even have comments about extracting hydrogen from the atmosphere for the ballooons. We know that the voltage is higher the greater the distance between the elevated plate and the ground. Was he considering maintaining the radiant energy collectors at 30,000 feet also? I think it likely. As far as I know he never tried it at Colorado Springs or anywhere else. That would have been quite an endeavor but we see very few notes and no photographs. Or at least I haven't seen any. I think he figured out later that he could do the same thing through the ground on July 4, 1899. It wasn't on July 4, 1899 because the July 5, 1899 entry has a note about extracting the hydrogen for the balloons. Maintaining balloons at those altitudes was plausible at that time because there were no airplanes there was an enormous beneits: rarefied air which breaks down and conducts more easily. See the following page and look at the first drawing. That was his simulation of transmitting in rarefied air for a patent examiner.
Colorado Springs Notes - Introduction
I flew to Hawaii some time ago and checked out the seatback display on the 737 I was on (in) and one of the things it showed was the conditions outside the plane. It was about -40F outside and we were at around 37,000 feet. My reading material for the flight? The Colorado Springs notes. Palm to forehead. Tesla also patented a method of refrigerating coils with "liquid air", as it was called then, to reduce the resistance of the conductors in the coil - a foreshadowing of superconductors. So transmitting at 30, 000 feet would be beneficial because lower air pressures, thinner air, and colder temperatures are all more conducive to conduction. He said many times his method was conduction, not induction. But there was one unknown factor that probably would have made that effort fail: the jet stream with winds up to ~250 MPH was unknown at that time.
I think when he concluded he could transmit through the crust of the earth he abandoned the ballooon idea simply because of the need for the altitude. There's been a lot of speculation about an "ionized channel to the ionosphere" but the jet stream would defeat that as well because the ioized channel would still be ions (matter) and the high winds would destroy the channel before it ever reached the ionosphere.
Nope. Well, maybe in a round about way. Tesla believed that if radioactive materials could be shielded from the cosmic rays they would not be radioactive. I contend that he used a nuclear battery. The battery was said to be a "normal" 12 volt battery but who would know what a nuclear battery was back then? Following his belief that the cosmic rays "activated" the radioactive materials, so to speak, it makes perfect sense. You have to keep in mind this was the 1930's and there were no controls on radioactive materials back then. None. The government controls came after it was proven that radioactive materials could be weaponized. Tesla also claimed he had developed a way to produce radium for one dollar a pound. Why would that be important to him? At the time radium cost about $58,000 per gram. Automobiles were in mass production and if he was proposing to power cars with radioactive material, the price would have to come way down. Well, at $1.00 per pound that would be about $0.0022 per gram. Also note that he said the car could power a home when not in use as transporation. I think the antenna that was said to be on the car was misdirection which, apparently worked quite well.
Radioisotope Batteries for MEMS
More interesting a few people have actually looked at powering cars with radioactive power via thorium which is much safer than uranium or plutonium and it hasn't been that long ago. There's some news of thorium power plants being developed recently also.
Cadillac’s World Thorium Fuel Concept
Thorium nuclear reactor trial begins - July 1, 2013
It might help with desulfation but if you hit it with too high a voltage I imagine it would boil off the elctrolyte.
So radiant energy and wireless transmission are two different things. Radiant energy collection is the collection of energy from nature. Transmission works regardless of the source. A couple of things to note: the radiant collector and transmission patents do not reference each other and the Wardenclyffe transmission project had it's own steam powered generator.
They are, however, weakly linked because radiant energy from the sun and other celectial bodies is transmitted wirelessly to the earth.
i am looking at wireless energy again..
what was learned? one its longitudinal energy from nature? two there is a hairpin at the receiver..
looking at the coil transmitter, its simple. a copper tube coil of two turns, but he add a secondary directly inside.
this can be experimented if you have the coils to work with.
the secondary coil is a free floating coil, and has a ground wire and antenna..
see patent Tesla.. this should be easy to come up with new interesting improvements.
I saw a vid, by eric dollar and i didn't realize how simple this is. one member here was working on the hair pin circuit by adding a power source to it. umm the power should come from the transmitter. so take a Tesla hair pin, and use wireless energy to power it up, not visa versa.
next we can advance in any number of ways.
take a pancake coil of many turns bi-filler if desired. now connect the outer edge to ground. next take the center tap and add a antenna.
what did we do? this is the basic of Tesla wireless transmitter.
will energy come off this coil? will there be current? I don't think so, unless you specifically tune to whoever it may be that already is sending out wireless energy. ELF for instance, or even tapping into shoe-man. someone is out there sending this energy all around us, wasted energy.
what i described was what the transmitter would look like. a alternating current need be applied to the 2 turn coil that is not in direct communication with the secondary.
want to know more?
https://www.youtube.com/watch?v=3uXL4_Yas2k#
