Watch full length.
That be you, Russ :D
Interesting with the AC "jacob's ladder", perhaps something to add on at some
point in time?
Thanks for sharing.
Watch full length.
Possibly the best video posted on YouTube:
https://www.youtube.com/watch?v=VMtRKJh8ZYg&feature=youtube_gdata_player
Things like this is why I do what I do have fun smile enjoy life kids are the best ;)
God bless Robert!
Watch full length.
https://www.youtube.com/watch?v=foIWltOShO0&feature=youtube_gdata_player
I agree, Watch full length everyone! This guy knows what he is talking about. He obviously wants someone else to build it so hes giving away all his ideas :)Quote from ~Russ/Rwg42985 on November 2nd, 2012, 03:28 AM Watch full length.
Thanks Russ.
I'm afraid it is, it's a term used in fringe science, which a lot of the forumQuote from Babble on November 1st, 2012, 06:39 PM I understand getting hydrogen and oxygen from water but it is not called HHO.Quote from Lynx on November 1st, 2012, 02:09 PM During electrolysis of water you get both H2 and O2 molecules, I.E out of 2 waterQuote from Babble on November 1st, 2012, 01:09 PM "HHO is Hydrogenoxide, which you get from electrolyses of water and what is used as browns gas. But the Oxide can be separated "
Isn't HHO the same as H2O, which is water?
molecules you get 1 molecule containing 2 oxygen atoms and you also get 2
molecules made of 2 hydrogen atoms each.
http://www.hytechenergyeurope.com/mgs/researchimages/hho.png
Hope this helps.
members here are exploring btw, to describe the gas obtained through electrolysis
of water.
Another term used is Brown's gas, but it's easier to just use HHO.
And the beauty of HHO is that when you burn it you get water again.
http://en.wikipedia.org/wiki/Oxyhydrogen
Btw, what would you like to call it?
If you need a simple term call it H2+O2 for hydrogen and Oxygen but HHO seems to be talking about some other effect. I watched the video, interesting. Why doesn't he just go to an engine testing facility and see if he can inject the gases into an engine while on a dyno?Quote from Lynx on November 2nd, 2012, 12:55 AM I'm afraid it is, it's a term used in fringe science, which a lot of the forumQuote from Babble on November 1st, 2012, 06:39 PM I understand getting hydrogen and oxygen from water but it is not called HHO.Quote from Lynx on November 1st, 2012, 02:09 PM During electrolysis of water you get both H2 and O2 molecules, I.E out of 2 waterQuote from Babble on November 1st, 2012, 01:09 PM FaradayEZ wrote: "HHO is Hydrogenoxide, which you get from electrolyses of water and what is used as browns gas. But the Oxide can be separated "
Hope this helps.
of water.
The layering of the noble gases inside the gas storage tank makes it difficult to thoroughly mix these gases before they are used in the popper.
I don’t think that the gas mixer that Russ built will do a proper job in mixing the noble gases together.
The light weight of helium and its propensity to rise can be turn from a problem into an advantage as follows:
The tank should be rotated end over end. This will force the helium to penetrate all the layers of the other noble gases. Such a rotation strategy will allow the walls of the tank to always force helium to the bottom of the tank in just one rotation cycle.
From this location, helium will be forced to rise under the influence of gravity through the layering and completely penetrate the other four layers of the noble gases.
When the tank is horizontally rotated, the smooth walls of the tank do not provide enough friction to force helium to the bottom of the noble gas layers.
To make vertical rotation more effective, the storage tank should be long and narrow to increase the linier distance that helium must raise. The distance that helium must travel is proportional to its efficiency, dispersion, and penetration of the other noble gas layers.
To test the ability of Russ’s new gas mixer to mix noble gases. Russ can fill a small balloon with the noble gas mixture then weigh it.
The experimental procedure is as follows:
Weight the balloon before it is filled with the noble gas mixture using a sensitive scale.
Fill it with a volume of the noble gas mix.
Now weight the balloon. If the balloon weighs less than the empty balloon, then the balloon is filled with only or mostly helium.
If the balloon rises, we know that Russ’s mixer is ineffective.
A suggested revision of Russ’s noble gas mixing device follows:
Strap the noble gas storage cylinder to a bicycle wheel.
Mount the bicycle wheel vertically so that the wheel rotates using a friction contact as is currently done by Russ’s mixing machine. A flat metal support connected to the wheel on the side opposite the cylinder might be a convenient way to mount and to support the wheel.
The other features of Russ’s gas mixer... timers, direction reversers etc… can stay the same.
The noble gas mixture should be removed from the cylinder immediately or as soon as possible when the cylinder lies in a horizontal position to minimize the possibility of gas layering.
trying to get back here guys... been extremely bisy trying to get more work done on the popper and controls/cap bank/ignition and pree-ionization...
EZ: please put a note in the doc some where to try a small orifice with a balloon on it on the chamber... i think it may have been mentioned but this will be a test i want to not forget. i want to see the slow ionization via a balloon size... ( after the leaky cup this may tel us some more interesting info about whats going on in there... ) THX
Quote from Axil on November 5th, 2012, 12:37 PM A suggested revision of Russ’s noble gas mixing device follows:
Flanigan has a vortex like twister device where Russ cylinder could be mixed..
If he would be approached in the popper way..
And why not fill the needles while'st still turning the device? (with a hose)
And keep shaking the needless offcourse...Do you have the video on when you work at the popperstuff?Quote from ~Russ/Rwg42985 on November 6th, 2012, 03:13 AM trying to get back here guys... been extremely bisy trying to get more work done on the popper and controls/cap bank/ignition and pree-ionization...Done, i'll uploade v1.6 within 10 minutes from nowQuote from ~Russ/Rwg42985 on November 6th, 2012, 03:13 AM
Is that the type of videos you're talking about?
Thanks EZ,
Does anyone have a cite on the "layering" of gas mixtures? I know you can get bodies of high molecular weight gasses to "pour" and hug the ground, but I thought that if you just let it thermally diffuse at room temperature, even the highest molecular weight gasses would mix thoroughly with low molecular weight gasses.
I can certainly believe that you'll get layering during plasma dynamics where the gasses are under enormous (albeit momentary) g-loading -- sort of like the separation of isotopes of Uranium via the Hexaflouride gas in an ultracentrifuge.
Two of the noble gases in the Papp gas mix are extremely heavy. And helium is very light.
Krypton is far heaver the iron, copper, or zinc, and xenon is also heavier than these metals in addition to tin, silicon, and antimony.
In a comparison, in a mixture of gold and water, how long will gold be suspended in a water mixture; well, not long at all no matter how long you mix them together.
To make a point in a recent Bob Rohner video, the Rohner brothers had a disagreement about the color coming from of the spark of their poppers. Bob said his spark was pure helium colored, whereas John’s spark was greener.
The reason for this is that Bob takes his gas from a premixed tank and John injects his gases individually in the old Papp style.
Bob gets mostly helium from a layered pre-mix tank into his popper, whereas John gets more of a mix of the five noble gases.
I am coming to the realization that the only way to fill a popper with gas is to separately inject the five gases individually as Papp did.
In the video of the Papp cannon, Papp uses five separate gas flasks to separately inject the gases into the cannon.
When the cannon explodes, it shreds to small pieces a 6 inch wide 3/8 inch thick steel pipe.
When properly done, the Papp reaction can achieve an explosive power of a few sticks of dynamite. We are not at that power level yet and we won't get there unless we sweat the details.
With all the talk on mixing, I realize from a practical view that a real word solution will be problematic. If the gas is that sensitive to mixing to work properly,
a person will never turn off the engine once its running. If you turn off the engine for a few minutes, it may not start. Can you imagine a car sitting in front of your house or in the garage, always running. I know I'm way ahead of the issue, we need to make it run, but it is food for thought.
Stop engine, vent to small cylinder. Start engine, shake cylinder, inject gas to cylinder and start ionizing. A small container could be tumbled with a starter, but it seems bizarre.
Popper Kit for auction you have until 13 November 2012 to put your bid in. You can put your bid in via sending me an email at RWG42985@aol.com
Thanks!! ~Russ
