Hi geenee,
I tried this with my flyback transfo. It was like in the video. But without bubbles.
But also the surface of the watersurface was "dancing" and beginn to turn like electrical field. Only had 14kV, but this is ok, I will try to increase.
The test was like we were thinking of:
One tube feeded by the flyback, the other tube was neutral and isolated against ground.
Also I took an other neutral cable and bring the cable in the position nearly to the water surface, an arc was visible which ionized the air. --> So the water has the potential like the tube and the output of the flyback. :)
Which also means there is a force on the water indeed.
This is very good. It is the basic of elongate watermolecules or to ionize.
Maybe I can increase the voltage, I need an other voltage supply!
The topologie is nearly the same to the one in the attachment.
It is compareable with the primary side of stans cell driver.
http://www.rexresearch.com/meyerhy/wo92-5.jpg
