2 Storage Conditions and Shelf Life
Nanobubble-enriched water storage conditions are critical to maintaining gas saturation and stability. Current best practice recommends using ungrounded, electrically neutral or positively charged containers—commonly neutral plastics like HDPE or PET, or positive stainless steel tanks—kept within a temperature range of 21–24°C. Maintaining these conditions prevents charge dissipation and contamination, thereby maximizing nanobubble longevity.
Updated Stability and Shelf Life
Recent comprehensive studies on hydrogen nanobubbles reveal that previous estimates of rapid decay (half-life ~6–8 hours) are likely conservative or context-dependent, often influenced by measurement techniques or container materials. Key findings include:
Hydrogen (H₂) nanobubbles at ~2 ppm (0.002 g/L) concentration in pure water at 21°C can remain stable from several days up to 1–2 weeks, particularly when stored in clean, ungrounded, positively charged plastic containers that reduce bubble coalescence and gas escape. The absence of negatively charged ions in such setups greatly reduces recombination losses.
Oxygen (O₂) nanobubbles, supersaturated at ~40 ppm (0.04 g/L), maintain stable dissolved oxygen levels for 1 to 10 days under similar storage conditions.
The overall nanobubble gas holding capacity, factoring in the stabilizing effect of positive surface charge bias, can extend nanobubble persistence to several months (up to 6 months or ~180 days) when water is stored in ungrounded, clean, and non-conductive vessels that preserve the electrostatic barrier preventing bubble collapse and dissolution.
Engine Fuel Injection Systems and Fuel Recycling
For applications where nanobubble water is used as engine fuel, special consideration must be given to the design of the fuel injection system and fuel return cycle to maintain nanobubble stability throughout operation:
Positive Charge Maintenance: All fuel system components in contact with nanobubble water—including engine injectors, fuel rails, and return lines—should be constructed or coated to maintain a positive electrostatic charge. This positive bias helps repel electron aggregation on bubble surfaces, thus prolonging nanobubble suspension and preventing premature coalescence or collapse.
Ungrounded Fuel Circuit: The entire fuel injection and return system should remain ungrounded electrically. Grounding dissipates the positive surface charge essential for bubble stability.
Fuel Injection Bypass Cooling: A cooling device should be integrated on the fuel injection bypass line before the return to the fuel tank. This unit ensures the returning nanobubble water fuel remains within the optimal temperature range (21–24°C), preventing heat absorbed from engine surfaces from degrading bubble stability.
Thermal Management: By controlling temperature and charge conditions within the fuel circuit, the nanobubble water fuel can maintain its saturation and gas suspension for longer durations, enhancing fuel efficiency and consistent engine performance.
Table 2: Stability Factors – Converted Units
Nanobubble Gas States in Water @ 21°C, 1 atm
PICTURE ATTACHED
Notes on Table Values
H₂ Saturation: Hydrogen nanobubbles remain stable at ~2 ppm for up to 1–2 weeks when stored in appropriately positively charged, ungrounded containers.
O₂ Saturation: Oxygen nanobubbles at ~40 ppm remain stable for 1 to 10 days depending on storage conditions.
Total Nanobubble Holding: Positive surface charge bias and ideal storage conditions extend nanobubble gas retention up to 6 months or more.
PICTURE ATTACHED
