PMBO 2020 FINAL Entry Video. NOW OPEN FOR POSTING
Re: PMBO 2020 FINAL Entry Video. NOW OPEN FOR POSTING
« Reply #1, on December 28th, 2020, 06:20 AM »
This Thread is officially Open for your Final 3 min Entry videos to be posted.
Remember to only link your video here. You can not upload the video to the forums.
Good Luck!
--Oz--
« Reply #2, on December 30th, 2020, 11:44 PM »Last edited on December 31st, 2020, 09:39 AM
Here is my advanced class entry, much more info in the video description, good luck everyone, thanks for watching.
And thanks to Russ, the admin's and the gang for putting on this years PMBO competition.
Quick Summery, now working:
New FET driver (2ED2108S06F) in all three drive modes.
Better FET (STW80NE06-10, 80A, 60V, 8.5milliOhm, TO-247 package) has not failed yet.(option IRFP064N)
New more sensitive hall effect trigger sensor  (A1104)
Hall effect coil current sensor (ACS758ECB-200B-PSF-T, 10mV/A)
Configuration: enable/disable each fet, combination of fets and their drive polarity though switches and jumpers with indicators.
indicator of coil current on hall trigger sensor (warns if coil current is on continuously from ball not rotating) and overheating the coil.
And the largest achievement:
Single low side drive, push/pull drive (with coil tied to Vcc/2), and full bi-directional H-Bridge fet drive.
This really opens the next level of testing for my project.
As a side bonus, it does solve the coil flyback voltage issue causing fet avalanche and blown fets. The highest drain voltage I have seen was around +/-20V in this mode. The fact that 99% of fet's have a body diode, and with the H-brige config, there is 4 ways the flyback voltage/current has a path to travel (called free wheeling mode).
https://youtu.be/K6xhW22r6xQ
Davy Oneness
« Reply #4, on December 31st, 2020, 11:42 PM »
I had lots of technical difficulties getting the videos together. And man, didn't realize how hard 3 min would be to try and get everything all in at the end, lol.
I did this all in one take in order to get up here by the clock run out. My "half way video" should shortly follow. It will at least be on my youtube page if I fall asleep before it finishes uploading, lol.
This RPS I built has a lot louder snap in person than the camera mic allows through. Even though I couldn't get my pulse motor running by end of the contest, I am pretty proud of the power supply I get to share with you all.
https://youtu.be/kn1iM8U3oko
