Forming continues.
EPG Static Electricity?
it Seams that there is very useful information around magnetic flow meters based on voltage vs flow rate
All information is here free on forum
Re: EPG Static Electricity?
« Reply #28, on March 27th, 2021, 10:51 AM »Last edited on March 27th, 2021, 10:53 AM
Often Said we must have eyes to see and ears to hear
For those skilled in the art
2 electrodes and electron extraction ( the Collector) the most important often left out pc clearly shown
to join new gas mixes or make them + missing electrons
We Know Stan Must have read this historical event Cyclotron
Treat as the entry step to epg
« Reply #29, on March 27th, 2021, 10:53 AM »Last edited on March 27th, 2021, 12:04 PM
Step 2 Accelerating with varying coil values sm to large shown here
not all same size
May be a very important detail if we are using these to accelerate the media of choice.
if not than it is a poor mans Cockcroft-Walton voltage multiplier in the stacked epg
and a pump in the single ring
if used in that way that stack can easily power anything you want.
DD
not all same size
DD
« Reply #30, on March 27th, 2021, 11:37 AM »Last edited on March 27th, 2021, 12:27 PM
Re This Picture
After a Considerable amount of study , i am confident to state this is a linear heat tube
If a Media like sensitive Mercurochrome or similar is used it will rapidly expand and collapse
In a Old Document with no source stated
When heated up it will actually surge away from the heat.
So when heat is applied to the side or the bottom in a specific point it will surge away from the heat and in doing
so push the fins of the turbine if in line ,( could the pump motor be a generator hmmm)
that then spins the shaft and fluid goes past the wire coils there for creating electrical power.
Special note for those skilled in the study of this topic
The redox reaction involved where mercury oxidizes the copper is: Hg2+ + Cu → Hg + Cu2+
this would cause copper to discolor but not dissolve
I know some people have investigated accelerators like van de graaff accelerator
As the Epg makes a certain level of power it can be multiplied with Cockcroft-Walton voltage multipliers
in some very old picture that is what you see with the accelerators and it opens the door of " it is in use."
look very careful at the labled 75 in diagram and way it is wired ,
I post this here to fill some of the gaps ,
Stan Made many versions of EPG we can see with study,
so did many others.
by knowing these things we can see the various parts and options to meet the same goal.
so did many others.
